Battery replacement experience
#11
#12
For what it's worth, the Bentley manual states that the battery should be replaced with a "cycle-proof" / "leak-proof" or AGM battery - which is good advice. I have had a couple of batteries leak in other cars, resulting in corroded battery trays. If that happens in our Audis, you have a corroded trunk, which is ultimately worse. All my cars, except for the Audi, have Optima batteries in them, which are AGM batteries. Also, the Bentley manual indicates that the Energy Management Control Module must be recoded when the battery is replaced (which is what the dealer is essentially saying, and charging an arm and leg to do). This should be do-able with a Vagcom. Does it make a difference? Don't know. But the Energy Management system is responsible for shutting down non-essential electrical components sequentially when the battery starts draining.
Take it for what it's worth.
old-dog
Chicago Discussion
11-28-2016 04:12 AM
stormchaser1967
New Member Welcome Area
09-01-2015 01:29 PM
