Brake Disc help info
Hi. I wanted some help with my decision about brake disc and pads. I have Audi A6 2010 2.7 140Kw. My rear brake pads are finished and wanted to put new one. Now when i inspected the disc i saw that the thickness is 20mm. According to the manual 20mm is the minimum thickness. My question is, because i need new pads and the disc is already at its minimum thickness, should i buy new discs or is it safe to resurface these?
Originally Posted by Nebitan Lik
(Post 25790958)
Originally Posted by raj99
(Post 25791022)
@Nebitan Lik you should be installing new pads and rotors. Since once you resurface you'll be under tolerance and you're better off doing the job right once vs wrong twice.
