Car will not turn over just shudders
OK i have 2005 Audi a6 3.2l quattro just recently its not turning over has good battery power. I'm hoping I can get help here before I take it to the stealer ship. Anyway the cel has been on for about five months. Every now and then abs flashes while driving on highway...I usually turn it off(until I can get it fixed). I have had to pull off the highway sometimes to turn the car off because it wil lose power but its fine when i restart it. Just bought the vag com cable to scan it, so I do not know a lot about what the numbers mean.
What its doing..Has power but will not turnover, was shuddering. I did add oil to to the car right before all of this started, not much tho. Did pull coils, driver side coils had oil on them clean them up. I guess a blown head gasket but that shouldn't stop it from starting. Any help and guidance you can give I appreciate it....
Thing i have done:
new spark plugs...new
camshaft sensors... new
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 42 46 47 4F 52 53 55
56 61 62 72 77
VIN: WAUDG74F15N062583 Mileage: 240840km-149651miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 1010
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F2 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0030
Revision: --H15--- Serial number:
Coding: 0000000000000000
Shop #: WSC 08166 444 54260
VCID: 2B5535AF8A295B79EA9-807E
3 Faults Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 12:01:17
Freeze Frame:
RPM: 576 /min
Mass Air / Rev.: 457.8 mg/str
Temperature: 7.5°C
Idle
Load: 75.3 %
Speed: 0.0 km/h
000870 - Camshaft Position Sensor B Bank 1 (G300)
P0366 - 006 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 3
Reset counter: 40
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 12:01:20
Freeze Frame:
RPM: 224 /min
Mass Air / Rev.: 316.1 mg/str
Temperature: 9.0°C
Start
Bin. Bits: 00010000
Speed: 0.0 km/h
000833 - Camshaft Position Sensor (G40)
P0341 - 006 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 40
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 12:01:20
Freeze Frame:
RPM: 224 /min
Mass Air / Rev.: 294.3 mg/str
Temperature: 9.0°C
Start
Bin. Bits: 00010000
Speed: 0.0 km/h
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 H HW: 09L 927 156
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 0061983
Coding: 0001002
Shop #: WSC 02325 785 00200
VCID: 2959CFA780D54969185-807C
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004511
VCID: 2643C49B91CB6611357-8073
2 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 155
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 19:52:28
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x4082
Hex Value: 0x0000
Hex Value: 0x008C
Hex Value: 0x00FF
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 19:53:05
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x4082
Hex Value: 0x0000
Hex Value: 0x008C
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10603401766087
Coding: 0000011
Shop #: WSC 08180 444 123991
VCID: 2541C397ECCD6D093CD-8070
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H43 0070
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H35 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 729 B HW: 4E0 035 729
Component: Interfacebox H43 0750
Revision: 00000000 Serial number: 360JU047506692
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 285FCAA39BDF706107B-807D
Subsystem 1 - Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
Subsystem 2 - Serial number: 00000000065426
Subsystem 3 - Serial number: 0112.10.040000000100010525ÿ
Subsystem 4 - Serial number: 010525ÿ
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 12
Reset counter: 39
Mileage: 237290 km
Time Indication: 0
Date: 2014.10.06
Time: 16:11:22
Freeze Frame:
Bin. Bits: 10
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000023 Serial number: 00000000072094
Coding: 0524326
VCID: 5BB5A56F9A09EBF95A9-800E
1 Fault Found:
01314 - Engine Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 38
Reset counter: 194
Mileage: 239303 km
Time Indication: 0
Date: 2014.11.09
Time: 08:04:46
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0013123
VCID: 66C3849B514BA611F57-8033
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 D HW: 4E0 035 111 A
Component: CD-Changer H44 0340
Revision: 00000000 Serial number: AUZ5ZBD6020625
Shop #: WSC 00000 000 00000
VCID: 1A3BE06BD5B3D2F181F-804F
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 A HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH28 0220
Revision: 09H28000 Serial number: 00359D073ZTI
Coding: 0013622
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME064B0152X
Subsystem 3 - Serial number: 6342CSME05485C242
Subsystem 4 - Serial number: 6351HSME04534E535
Subsystem 5 - Serial number: 6361HSME04530B06/
Subsystem 6 - Serial number: 6371VSME042043130
Subsystem 7 - Serial number: 6381VSME03050A63B
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90022042750393
Coding: 0002041
Shop #: WSC 02323 785 00200
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H09 0660
Revision: 00300000 Serial number: 4I212FFA4
Coding: 0065263
Shop #: WSC 08180 444 100034
VCID: 1E33EC7BC99BBED17D7-804B
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 0800804A07041C
Coding: 6CFE73CC1B1104
VCID: 275DC99F96C17F190E1-8072
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 195
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 12:02:14
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 195
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 12:02:14
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 61C99787B865C129005-8034
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: ya'
Coding: 0035563
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01001237020000
Coding: 0423997
VCID: 2C5736B38F275C41E33-8079
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F5 910 223 B HW: 4F5 035 223 C
Component: DSP-High C6 H14 0220
Revision: PROD_01 Serial number: 00000000011833
Coding: 0000016
VCID: 224BD88BFDE39A3159F-8077
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 7
Reset counter: 191
Mileage: 240025 km
Time Indication: 0
Date: 2014.11.20
Time: 07:57:28
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000038936
Coding: 0001114
VCID: 5EB3AC7B891BFED13D7-800B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: x†'
Coding: 0035563
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0005022
Shop #: WSC 08166 444 73066
VCID: 204FD283F3EF88214FB-8075
1 Fault Found:
02433 - Supply Voltage for Right Parking Brake Motor (V283)
011 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11101011
Fault Priority: 2
Fault Frequency: 254
Reset counter: 218
Mileage: 233104 km
Time Indication: 0
Date: 2014.07.26
Time: 12:16:49
Freeze Frame:
Voltage: 11.28 V
Count: 117
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 A HW: 4F0 907 357 A
Component: AFS 1 H03 0010
Revision: 00000001 Serial number:
Coding: 0000016
Shop #: WSC 08180 444 103883
VCID: 2447DE93E7F794012B3-8071
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H02 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH05 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 C HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 352JO047568200
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0400
Revision: 00000000 Serial number: 00000000067922
Shop #: WSC 08212 444 64365
VCID: 2345DD8FE2F99339529-8076
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 2410120362
Coding: 344630393135313035432056413032343130313230333632
Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H09 0010
Coding: 0035370
VCID: 69D98FA740558969D85-803C
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H09 0010
Coding: 0035370
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 HW: 4E0 862 335
Component: Handyvorb2 H10 0080
Revision: 00000000 Serial number: 00000007504879
Coding: 0010900
VCID: 60CF9283B36FC8210FB-8035
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Mileage: 239616 km
Time Indication: 0
Date: 2014.11.13
Time: 16:13:45
End-------------------------(Elapsed Time: 02:40)--------------------------
Thing i have done:
56 61 62 72 77
3 Faults Found:
P1653 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 12:01:17
Freeze Frame:
RPM: 576 /min
Temperature: 7.5°C
Idle
Load: 75.3 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 40
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 12:01:20
Freeze Frame:
RPM: 224 /min
Temperature: 9.0°C
Start
Bin. Bits: 00010000
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 40
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 12:01:20
Freeze Frame:
RPM: 224 /min
Temperature: 9.0°C
Start
Bin. Bits: 00010000
Speed: 0.0 km/h
Coding: 0001002
Coding: 0004511
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 155
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 19:52:28
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x4082
Hex Value: 0x0000
Hex Value: 0x008C
Hex Value: 0x00FF
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 19:53:05
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x4082
Hex Value: 0x0000
Hex Value: 0x008C
Hex Value: 0x00FF
Coding: 0000011
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 39
Mileage: 237290 km
Time Indication: 0
Date: 2014.10.06
Time: 16:11:22
Freeze Frame:
Bin. Bits: 10
Coding: 0524326
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 38
Reset counter: 194
Mileage: 239303 km
Time Indication: 0
Date: 2014.11.09
Time: 08:04:46
Coding: 0013123
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Coding: 0013622
Coding: 0002041
Coding: 0065263
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 195
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 12:02:14
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 195
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.20
Time: 12:02:14
Coding: 0082946
Coding: 0035563
Coding: 0423997
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 191
Mileage: 240025 km
Time Indication: 0
Date: 2014.11.20
Time: 07:57:28
Coding: 0001114
Coding: 0035563
Revision: --H04---
Coding: 0005022
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 218
Mileage: 233104 km
Time Indication: 0
Date: 2014.07.26
Time: 12:16:49
Freeze Frame:
Voltage: 11.28 V
Count: 117
Coding: 0000016
Coding: 0000002
Coding: 0035370
Coding: 0035370
Coding: 0010900
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Mileage: 239616 km
Time Indication: 0
Date: 2014.11.13
Time: 16:13:45
thx for the response and help...I cleared the faults and rescanned here is what came up. I now have low battery but its been sitting for three day since this no start up issue.
Thursday,04,December,2014,11:16:35:11371
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WAUDG74F15N062583 License Plate:
Mileage: 240840km-149651mi Repair Order:
56 61 62 72 77
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
1 Fault Found:
005634 - Power Supply Terminal 30
P1602 - 008 - Voltage too Low
Freeze Frame:
Fault Status: 01011000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 240843 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 0.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Coding: 0001002
Coding: 0004511
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 155
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.24
Time: 07:34:28
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x4082
Hex Value: 0x0000
Hex Value: 0x0084
Hex Value: 0x00FF
Coding: 0000011
Coding: 0000003
Coding: 0524326
Coding: 0013123
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Coding: 0013622
Coding: 0002041
Coding: 0065263
Coding: 0082946
Coding: 0035563
Coding: 0423997
Coding: 0000016
Coding: 0001114
Coding: 0035563
Revision: --H04---
Coding: 0005022
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 218
Mileage: 233104 km
Time Indication: 0
Date: 2014.07.26
Time: 12:16:49
Freeze Frame:
Voltage: 11.28 V
Count: 117
Coding: 0000016
Coding: 0000002
1 Fault Found:
02276 - Quiescent Current Stage 5
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.24
Time: 07:34:28
Coding: 0035370
Coding: 0035370
Coding: 0010900
End-------------------------(Elapsed Time: 02:32)--------------------------
56 61 62 72 77
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 240843 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 0.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Coding: 0001002
Coding: 0004511
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 155
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.24
Time: 07:34:28
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x4082
Hex Value: 0x0000
Hex Value: 0x0084
Hex Value: 0x00FF
Coding: 0000011
Coding: 0000003
Coding: 0524326
Coding: 0013123
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Coding: 0013622
Coding: 0002041
Coding: 0065263
Coding: 0082946
Coding: 0035563
Coding: 0423997
Coding: 0000016
Coding: 0001114
Coding: 0035563
Revision: --H04---
Coding: 0005022
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 218
Mileage: 233104 km
Time Indication: 0
Date: 2014.07.26
Time: 12:16:49
Freeze Frame:
Voltage: 11.28 V
Count: 117
Coding: 0000016
Coding: 0000002
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 240843 km
Time Indication: 0
Date: 2005.09.24
Time: 07:34:28
Coding: 0035370
Coding: 0035370
Coding: 0010900
OK i have 2005 Audi a6 3.2l quattro just recently its not turning over has good battery power. I'm hoping I can get help here before I take it to the stealer ship. <b>Anyway the cel has been on for about five months. Every now and then abs flashes while driving on highway...I usually turn it off(until I can get it fixed). I have had to pull off the highway sometimes to turn the car off because it wil lose power but its fine when i restart it. </b>Just bought the vag com cable to scan it, so I do not know a lot about what the numbers mean...
Well as others have said, make sure your batter is actually good and properly tied down...since i'm not sure as to what your level of maintenance actually is.
Furthermore, it may be a 'stealer-ship' to you, but I suppose it's better than the enormous paper weight in your drive
you might have an intake issue, but it's near impossible to deduce. is the alternator gone? Starter motor fried?
At this point, if it were me, I'd bite the bullet and get it thoroughly checked. You pay for expertise.
No i never changed the battery, bought the car 7 months ago and have no idea what they did or did not do to it. Battery reader in the car says its at 5 % now. I will get it tested. Again thx for the responses.
ok...this is pretty obvious now. Don't test the battery...it's DONE. Just get a new one and install it and you'll be fine. At 5% you are beyond running on borrowed time and my guess is that the original battery is in the car, which is by now 10 years old!
Brad Meyer
9
04-20-2019 07:08 AM
ELVIS12345678
10-03-2017 02:21 PM
Spurian
RS4 (B7 Platform) Discussion
12-07-2008 09:33 AM
