Child Lock Window Stuck
So here's my problem - the child lock for the driver's side rear window is constantly lit and the window can only be opened through the driver's master switch. I can hear a faint click when pressing it, but not like the passenger side. I tried the "hold the lock and then try opening the rear window" trick, along with some other tips I've read on the forum, but to no avail. I ordered a new switch, thinking maybe there was a problem inside and I didn't want to bother taking it apart because the price was good and my switch was in pretty worn shape anyways. Installed it today and the problem remains.
I now believe it to be something in the rear door, but what that something is, I don't know. Any thoughts? Thanks for any help. |
Any thoughts on what I should look at to fix this?
Last try - does anyone have any idea where I should look to troubleshoot this or am I the first one to have this issue?
Originally Posted by 0642A6
(Post 24077560)
I now believe it to be something in the rear door, but what that something is, I don't know. Any thoughts? Thanks for any help. HAPPY NEW YEAR |
Have you accidently activated the switch in your door that opperates the child-locks?
Page 46 doors & windows. To quote from the hand book :- on the drivers door "press the left or right (pic of child) button to switch the child-proof on the corresponding rear door on and off. The diode in the switch will light up when the child-proof switch is activated; * Electric windows in the corresponding door. * Door handle on the inside of the corresponding door. http://https://forums.audiworld.com/...1&d=1294000053 |
rear window problem
Do both rear windows not work when trying to use the rear door switches but can be operated by using the master switches on the drivers door?
If so its likely to be your child lock switch not engaging /disengaging properly - it can usually be fixed bt taking the switch apart. Confirm that these are the symptoms |
Originally Posted by pcamaj
(Post 24083215)
did u check if there is a manual switch, anywhere in the rear door... like "child lock" or whatever it may be?? just a thought...
HAPPY NEW YEAR |
Originally Posted by exocet
(Post 24083534)
If so its likely to be your child lock switch not engaging /disengaging properly - it can usually be fixed bt taking the switch apart. Confirm that these are the symptoms The child lock light is constantly lit corresponding to the driver rear window. When I press the child lock for the passenger side, I hear a solid 'thunk' and the window is locked. Same when I depress the switch to unlock the window. When pressing the driver's side lock, however, I hear a faint 'tick, tick', the light remains lit, and the window can only be operated from the master switch. I just installed a brand new switch, and it has the same problem. Thanks for any help. |
were you able to fix the problem because i have the same issue but i have a c5
Originally Posted by PapatoeSC
(Post 24090195)
Does anyone know if the light in the master switch is lit/unlit based on the status of something inside the rear door? i.e. if there is a mechanical lock that triggers the light when it's activated, or if the light in the master switch is purely electrically controlled via relays and what not. If I knew what component drives that light being lit (and is keeping it lit), I would know where to go next. Thanks. |
