Door Does Not Open and Stays Locked
My car started doing something very strange lately. When I unlock all of the doors the rear driver stays locked and does not open from outside. I have tried everything but I have not been able to figure out what is causing this. Has anyone had this problem and how did you fix it? Thank you.
Really, only I got this?
Whilst this may sound pretty strange, have you recently replaced the battery?
Aftermarket batteries can cause some wacky issues with these cars. |
Originally Posted by jujuC6
(Post 24320931)
Originally Posted by Alister
(Post 24320964)
Originally Posted by uberwgn
(Post 24320982)
No, Juju, our 2006 car does the same frequently. Only on the passenger side (rear). I have no idea what's causing it and have not been able to correct it.
i have the same issue with my left-rear door. unable to open/unlock from the outside, but i'm able to open it from the inside so i'm not sure if it's exactly the same issue as yours.
i have the keyless entry and i have read in other posts that the door handle itself will need to be replaced to address this issue. vag-com result from my vehicle is as follows: Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 E HW: 4F0 959 795 E Component: TSG HL H21 0050 Coding: 0051754 Shop #: WSC 02335 785 00200 VCID: 2E591B7AB90C649 1 Fault Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 22 Reset counter: 128 Mileage: 52905 km Time Indication: 0 Date: 2012.03.24 Time: 15:48:36 |
Well I have a spare door locking module for the front LH door (passenger side in RHD) if anyone would like to purchase it, as I had the same code and some issues with the operation.
Tried replacing the part with the new part, which didn't fix it. Replaced the battery with a genuine item (and coded it appropriately in the battery management system) and all good! Don't ask me how/why exactly, but it fixed it! |
Originally Posted by revangel
(Post 24321562)
(Post 24321651)
