Excess Engine movement
I continue to have my engine jerk back and forth when travelling at slow speeds (ie. in stop and go traffic). I replaced my snub mount when I got the car about 8 months ago. I don’t think my motor mounts would be bad because those will throw a code, correct? I have also recently replaced my upper control arms and stabilizer links on both sides. None of this has improved the herky jerkiness. The new snub mount got rid of the excessive "thump" I would always feel, but there still seems to be waaaaaay too much jerking of the engine at slow speeds. Can anyone else relate to this? What could this be or is it just normal for our cars?
Car is 2006 A6 3.2 (116 K miles). Thanks. |
Maybe trans mounts? Engine and trans are inline. Have someone power brake while you are looking at trans mounts. Even if your engine mounts are totally busted..you wouldnt feel it.
Originally Posted by Nurke
(Post 25228645)
Originally Posted by akingzkid
(Post 25228666)
Thanks Nurke. I have actually looked at the trans mount myself. Isn’t there only one? I had plenty time to see it when I had the car in the air on a lift was changing my transaxle fluid a few months ago. It looked to be in great shape. you need to apply its weight..power..tension on its wheels..axles..trans...to see what actually happens there. |
Motor mounts don’t always throw a code. |
(Post 25228680)
There are 2 trans mounts. You need to power brake it. Activate parking brakes..someone pushing brake pedal with left foot and and tap gas pedal with right foot...in drive and then in reverse..do not lay under the car...you newer know how streight is the one holding brake pedal down and how deep will push the gas pedal..dont want get run over.
you need to apply its weight..power..tension on its wheels..axles..trans...to see what actually happens there. https://cimg2.ibsrv.net/gimg/www.aud...62627c2b5d.jpg https://cimg1.ibsrv.net/gimg/www.aud...d7cf2dc98a.jpg |
Originally Posted by KevinGary
(Post 25228850)
Bad front lower control arm bushings or a dirty throttle body can also be the cause.
(Post 25228865)
Ok. I can have my son do this with me. Can either of the trans mounts be seen in this picture? I think one of them can be.
https://cimg2.ibsrv.net/gimg/www.aud...62627c2b5d.jpg https://cimg1.ibsrv.net/gimg/www.aud...d7cf2dc98a.jpg It was quite apparent when my motor mount was broker, It came out in 2 pieces :eek: But I could not tell until I actually had to remove it when swapping the trans. |
Originally Posted by kelisko
(Post 25229954)
