A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Front Axel bolt torque on 05 4.2 ???
Old 10-20-2013, 02:23 PM
KnappAttack's Avatar
Default Front Axle bolt torque on 05 4.2 ???
Changed my front wheel bearings yesterday with bearings ordered from from ECS Tuning. Was hoping the bolt tq. be in the instructions but was not. I hit the new bolts that came in the kit with 133 ft. lbs. and added 90 deg. Don't think I'd be able to go to 180 deg. as I had a 3ft pipe extension on my 1/2" breaker bar and it was flexing like a banana. Have to drive the car to work tomorrow, anyone know the Tq and extra twist at all????
Old 10-20-2013, 09:06 PM
A6Gary's Avatar
Per the Bentley Manual, the four bolts (M12) that secure the wheel bearing housing, which are to be replaced after removing, are to be tightened to 80 N–m (59 lb–ft) plus an additional 90 degree turn. Since you have over tightened them, you should remove and replace with new bolts because the bolts have been stretched beyond their yield strength.
Old 10-21-2013, 04:07 AM
Thanks, but I'm talking about the big axle bolt that hold the axle on, not the bearing housing bolts.
Old 10-21-2013, 09:27 AM
newa6er's Avatar
I had trouble getting to 180*, I think I was at ~150* and stopped, it's worked fine for two year
Old 10-21-2013, 10:12 PM
A6Gary's Avatar
Then that bolt is to be tightened to 200 N–m (148 lb–ft) plus an additional 180 degree turn. The Bentley Manual states to have someone press the foot brake with the vehicle is sitting on the ground while another tightens the bolt. When I changed the front crank bolt (which is specified to be tightened to the same) on my '96 A6, I tightened it first using my 150 lb–ft torque wrench, then using a 1/2" drive breaker bar + an extension from my floor jack to achieve the 180 degree turn (in two 90 degree segments). Did that several times.
Old 10-22-2013, 05:20 PM
OMG, If I have to get another 90* on it I'm going to need to use a 3/4 drive breaker. Your sure that's for the 4.2?
Thanks A6 Gary!
Old 10-22-2013, 11:36 PM
A6Gary's Avatar
Yes.
N'Syncro
33
02-16-2020 03:12 PM
ohsigmachi
03-29-2016 05:04 AM
marshap1
Wheels & Tires Discussion
09-06-2015 12:21 PM
A4QuattroV6
Audi allroad
09-02-2015 08:41 AM
jigaro
10
09-02-2015 05:42 AM
Quick Reply: Front Axel bolt torque on 05 4.2 ???
