Front sway bar links, replace on the ground?
I've been searching for an answer to this both on the forums and elsewhere, but I can't seem to find anything clear.
My front passenger side is clunking and clanking, and I'm sure all the bushings and stuff are going out. I thought I'd start with the swaybar end links, but right now, I'm on a gravel drive, so I don't want to jack the car up. Can I replace these on the ground, or on low ramps - i.e. wheels on the ground? Or is there any tension on the sway bar/links when the car is just sitting there?
- S
- S
Yes you can. I have done this in the past. For easier access you will have to turn the wheel to the side you are working on and lock the steering by removing the key.
There is no “stored mechanical energy” in the sway bar system. Like the springs, they have tension on them. As long as both wheels are at the same height, there’s no tension on the bar or endlinks.
Also, thanks for your videos - they've helped me navigate the new-to-me A6 through a few DIYs already.
- S
You're cool. By the way, have a scissors jack on hand. While installing the new links, you may need to slightly jack up the sway bar end to be able to place the bolt through.
Sommerfeldt (02-17-2021)
Depends on how you plan on replacing them. Do you want tension on them or not?? Lol...
Front sway bar is there to make sure your both front wheels are down on the ground when making turns at higher speeds....for better traction and steering control. It means that if you make a left turn..front left side will lift up...the sway bar will keep it down.
Now...if you are replacing one side by lifting up only one side...it will be harder to do it. A lot of tension.
Long story short...lift both sides on front to replace links as easy as you woud replace shoe strings...
On the other note...i have worked on hundreds of audi knocking issues....and not single one had links bad....they are not joint ball links..just rubber bushings...i would suggest to double check upper control arms...they go bad.
i hope i was able to help a bit...
- S
@Sommerfeldt I hope you made it. I did it again the other day and this time I recorded it. Here is the video:
Nepok
09-19-2005 09:59 PM
computrtutr
04-04-2003 06:01 PM
cpayne
Audi Original "S" Cars
02-27-2003 07:30 AM
