How badly am I screwed? P0021
#41
Hi. Quick question if you dont mind. How do I get to n208 valve /selenoid on a 2004 s4 ? B6 4.2. Mine is stuck and I need to replace it, but have no idea how to get to it. Please help. Thank you in advance.
Hi. Sorry to hear that. By elsa to P0021 u have to do this to check if the "Camshaft Adjustment Valve 2 -N208" is working properly.for that u need multimeter to check the voltage and resistance. let me copy them and attach the pics
Camshaft Adjustment Valve, Checking
This procedure is used to check the Camshaft Adjustment Valves -N205 and N208-.
Special tools and workshop equipment required
t Multimeter -V.A.G 1526 A- or equivalent.
t Voltage Tester -VAG1527B- or equivalent.
t Adapter Cable (121-Point) -VAG1598/31-.
t Connector Test Set -VAG1594C-.
Test requirements
l Fuse for valve for camshaft adjustment OK. → Wiring diagrams, Troubleshooting & Component locations.
l Ignition switched off.
l The Fuel Pump (FP) Relay -J17- OK. → Chapter.
Note
Voltage for camshaft adjustment solenoid valves is supplied via the Motronic Engine Control Module (ECM) Power Supply Relay -J271-.
Test sequence
Cylinder bank 1 (right):
– Disconnect the electrical connector -2- from the Camshaft Adjustment Valve 1 -N205-.
A24-10017
Cylinder bank 2 (left):
– Remove the screw -arrow- retaining the coolant reservoir.
A10-1522
– Disconnect the electrical connector from Engine Coolant Level (ECL) Warning Switch -F66- at the bottom of the coolant reservoir and set aside the coolant reservoir with the coolant hoses -1- and -2- connected.
– Disconnect the electrical connector -3- from the Camshaft Adjustment Valve 2 -N208-.
A24-10046
Checking internal resistance
– Using the Multimeter -V.A.G 1526 A- or equivalent, check the following wiring connections for open circuit.
Specified value: 8 to 13 Ω.
If the specified value is not obtained:
– Replace the faulty Camshaft Adjustment Valve.
If specified value is obtained:
Checking voltage supply
A96-0342
– Using the Voltage Tester -VAG1527B- or equivalent, check the following wiring connection for voltage.
A24-0331
Harness connector
Terminal Measure to
1 Engine Ground (GND)
– Operate the starter briefly:
The LED must light up.
– Switch the ignition off.
If the LED does not light up:
– Check the wiring connection from terminal 1 of the electrical harness connector via fuse to the Motronic Engine Control Module (ECM) Power Supply Relay -J271- terminal 2 for an open circuit:
Specified value: Wire resistance max 1.5 Ω.
– Check the wiring for a short circuit to Battery positive (+) or an open circuit.
– If necessary, repair the wiring connection.
If the LED lights up.
Checking activation
– Connect the Adapter Cable (121-Point) -VAG1598/31- to the wiring harness of the Engine Control Module (ECM) -J623- ; the ECM is not connected. → Chapter.
– Using the Adapter Cable (121-Point) -VAG1598/31- and Multimeter -V.A.G 1526 A- or equivalent, check the following wiring connections for an open circuit.
l Camshaft Adjustment Valve 1 -N205- (bank 1).
A24-0331
Harness connector
Terminal Test box
Socket
2 115
l Camshaft Adjustment Valve 2 -N208- (bank 2).
Harness connector
Terminal Test box
Socket
2 120
If the specification is not obtained:
If no malfunctions are found in the wiring:
– Replace the Engine Control Module (ECM) -J623-. → Chapter.
If no malfunctions are detected:
– Replace mechanical camshaft adjuster. → Engine Mechanical; Rep. Gr.15.
Assembly is performed in the reverse order of removal, note the following:
Final procedures
After repair work, the following work steps must be performed in the mentioned sequence:
1 - Check the DTC memory. → Chapter.
2 - If necessary, erase the DTC memory. → Chapter.
3 - If the DTC memory was erased, generate readiness code. → Chapter.
– End diagnosis and switch the ignition off.
Test requirements
Note
Test sequence
A24-10017
A10-1522
A24-10046
A96-0342
A24-0331
Harness connector
Terminal Measure to
Checking activation
A24-0331
Harness connector
Terminal Test box
Socket
2 115
Harness connector
Terminal Test box
Socket
2 120
Final procedures
#42
#43
Wow. This looks way more then I bargain for. For some reason I thought those would be somehwere easy accessible. .. on top of the valve cover or someething. Pshhh. Here goes my weekend heh.
Camshaft adjuster is I think its this - 079109087N.
#44
Yeah, looks like its a time consuming. It looks like the electrical Solenoid is not serviced separately on these. Its comes with the timing case from the dealer as part number 079109204J. The other part number that you listed is for the camshaft adjuster that is a mechanical unit that attaches to the back of the camshaft.
dariusps3
12
11-27-2022 06:05 AM
PingBing
Q7 MK 1 Discussion
11-19-2018 04:08 AM
dukesean
Q7 MK 1 Discussion
02-17-2017 01:13 PM
