How to use Air Conditioning?
I have an 2007 Audi a6 how do I turn on the air conditioning? I have to turn off econ right? I've tried setting my temp control on both sides to "low" when I press the econ light, it doesn't turn off, it stays red. Any ideas ? Or am I doing something wrong. When the car first turns on, I press the ECON button, the red light goes off, but comes back on.. afterwards, it never will go off If I press it.. only when first turning the car on.
Deja, you want the red light on the ECON switch illuminated to turn off the A/C compressor.
I want air conditioning.. for hot summer. Doesn't the econ light have to be off? If it needs to be on "red" then how do I get cold air . I put it on low and all it does it blast air from outside.
Have you tried holding the button down? It's possible the car is indicating a problem by not letting you switch it off. Have it checked for codes...
If I hold the bottom then the whole climate control turns off. As for checking for codes, you mean with like a scanner the one that will tell you what a check light code is? If so, I have no codes, I've used my scanner recently.
Cdeer
A6 (C7 Platform) Discussion
02-19-2019 02:19 PM
audiinnc
05-01-2007 04:35 PM
