HVAC Drain Line
HVAC Drain Line
Hi i would like to know where is the air con drain line exit point is on my Audi A6 C6? As i think it is blocked cause I can hear water sloshing around on the passenger side/armrest.
There is two drain under the console. On both side under the carpet. Thoses drain are draining your ac radiator. They drain over the heat shield over the exhaust. The only way to see it is to remove the carpet... They could be just unplug from were they was... And water goes in the bottom of your car.
Hi Guys
the carpets are not wet. I will try and remove the carpet and have a look. I think it is more on the left passenger side i hear it. I dont think its in the plenum chamber? As i never used to hear it its been about 3 weeks now. so I remove the carpet at the back seats and i should see the drain lines? How would i unclog it?
You don't say what year it is.
The floor of the A6 has a double skin, there could be water between the two layers.
Remove the under tray on the passenger side and pull the bungs out underneath.
Any water in there will drain out.
Above is my car with underlining off, blue box & stick are the drainage bungs... remove these bungs
