Intake Manifold Runner (Bank 2)
AUDI A6 2.7TDI sline 2008 Avant
I have an odd issue. I have run a diagnostics on my car and get the below error code (engine light comes on). Initial thought was the manifold motor had died. So a few months ago I changed the lever arms on manifold, seemed to fix issue for a few days till I refueled car. So I left the error for a bit. Last week I swapped the manifold around (driver side to passenger vice versa), Reset the DTC code, restarted car and engine light went off-:-). refueled car, immediately after I started the car and the engine light came on ! I'm confused as to what the fuel cap has to do with the engine management light coming on. So now I am stuck as to what the cause is, I don't want to start replacing manifold motors, flaps etc if the issue is to do with something else. I would really appreciate guidance on this! :-( ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4F5 910 401 Q Component: 2.7L V6TDI G000CG 0020 1 Fault Found: 004120 - Intake Manifold Runner (Bank 2) P1018 - 001 - Lower limit not reached Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 1 Mileage: 165345 km Time Indication: 0 Date: 2017.01.15 Time: 11:16:54 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 11.70 V Duty Cycle: 20.5 % Duty Cycle: 88.8 % Duty Cycle: 20.5 % Readiness: 0 0 1 1 1 Thanks, PC :confused: |
