Is this legit? ...and will it fit?
#41
Some more pics attached!
#44
not the same seller, but these look like it http://www.ebay.com/itm/2-x-2005-2008-Audi-A6-Q5-Q7-9-LED-Daytime-Running-Lights-DRL-LED-009-/170889241063?pt=Motors_Car_Truck_Parts_Accessories&hash=item27c9cae1e7&vxp=mtr
I paid $100 when I got them - guess price has dropped significantly.
#45
am_ver - Love the new grill.
I took my wife to a concert a few months back and a drunk back into me (the bastard) and crushed my front plate. Not a lot of damage but instead of rushing out and replacing the grill ASAP I wanted to look for a face-lift. The information on this thread was exactly what I needed.
From what I understand on my model (06 3.2 FWD) I will need to cut off tabs and use a heat gun to mold or push back the plastic to make it fit. Let me know if I have that right.
Looking to use this grill I found on Amazon. Has any one bought this grill? If so, thoughts or advice?
#46
^ The one you linked from Amazon seems like the same one I bought from dubstopimports.com
except I purchased the gloss black trim.
I would buy it on ebay if I were you. You get a better price and merchants really care about their ebay rating, so they ship faster. I bought directly from dubstop and it took them awhile to even ship it. I bet if I bought it through eBay, they would have been a bit quicker.
BTW, I did not have to cut any tabs from the grille when installing on my Pre-Facelift 2007. I did however need to cut two sections of the center band (of the bumper cover where the grille sits) out so the grille would sit down flush (with a dremel it took a minute tops)
The whole install takes time! My main issue was that the screws holding the OE grille in place did not fit the aftermarket grille. That added some time since I had to source screws that fit. Total time was close to 4 hours.
Last edited by cal3thousand; 03-29-2013 at 03:21 PM. Reason: clarifying location of cut
#47
Thanks for the info on the screws and total time. I thought Amazon might deliver a better quality item than eBay (I'm a novice eBay-er) and it shows in stock so delivery time should be quick.
Did you use a clear coat on the grill before the install?
#48
No, I did not use any paint. It seems to be painted with an automotive finish.
I will go over it with Opti-Coat 2.0 when I do the whole car in a couple weeks to add some protection, but that's it.
One more thing to note, the plastic surround (at least on the one I got) was not perfect. You will be able to notice (before you install) small imperfections where the screw posts are on the back side. I think this is due to the molding process not being a SUPER high quality. It's only noticeable at certain angles and is very small.
That being said, I thought about it long and hard before installing. I almost returned it until my wife told me to go ahead with it. Now that the grille has been on there, I admit that I have not noticed the imperfection at all, although I know it is there and can find it when I want. No one else will know it is there. If they do, there way too close to my car to begin with.
#49
Mike
