Light Sensor Defective
Hi,
I have a 2005 Audi A6 3.2 with vagcom error: Friday,16,January,2015,15:49:24:32264 VCDS Version: Release 11.11.3 Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Control Module Part Number: 4F0 910 279 HW: 4F0 907 279 Component and/or Version: ILM Fahrer H14 0080 Software Coding: 0013123 Work Shop Code: WSC 02335 785 00200 Additional Info: 4F1910113 Wischer AudiC6 H05 0150 4E0910557 REGENLICHTSENSORH10 0040 VCID: E6C92841D17C6C9 1 Fault Found: 02382 - Sensor for Light Detection (G399) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 213 Mileage: 119936 km Time Indication: 0 Date: 2015.01.16 Time: 15:47:00 I replace the light sensor on the dashboard. The problem is still there. When the headlights are set to Auto the headlights turn off/on properly. However, the interior dashboard lights do not. They are always off. Any ideas? MMI is updated to the latest. Thanks in advance. |
Did you clear the code and see if it is coming back? And if all of your fuses are good?
Yep, cleared the code. It comes back. No bad fuse. The fuse would power the whole module so other things would fail as well. Is it possible it is a bad comfort module?
Well if you have no error for the comfort module I wouldn't touch it.
If replaced the sensor and I'm
Not replacing the comfort module the only thing left is the harness or could it be coded incorrectly? I checked and it seems in order. |
Same issue and same error code G399 with 2006 A6. I pulled the sensor, and the error changed. Based on that ordered a new (expensive!) sensor. Will update when I change it. Did you ever resolve your problem?
Replaced sensor
Originally Posted by David Hoerl
(Post 25396020)
Originally Posted by daniel5420
(Post 25396033)
yeah I just replaced the sensor part on the mirror. Fixed it. Found the part used on eBay. Cheap.
