MIL came on yesterday and car went into limp mode any insight?
Never had any issues with the car before this. I checked the MIl with VAGCOM and it showed the following:
Address 01: Engine Labels: 06E-910-559-BKH.lbl
Control Module Part Number: 4F2 910 559 H HW: 4F1 907 559 E
Component and/or Version: 3.2l V6 FSI 0040
Software Coding: 010D0109190F0120
Work Shop Code: WSC 08159 444 178875
VCID: 31633862A80593909E2
1 Fault Found:
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 009 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 4
Fault Frequency: 3
Reset counter: 40
Mileage: 69232 km
Time Indication: 0
Date: 2013.04.11
Time: 18:14:59
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 125.4 mg/str
Temperature: 66.0°C
Pressure: 3.5 bar
Voltage: 13.67 V
Temperature: 30.0°C
Readiness: 0000 0000
I cleared it and it hasn't come back on but I haven't really driven it yet just let it run in the garage for a good 20 minutes. Still have CPO warranty and my 45K mile service is coming in a couple thousand miles, so I'll probably bring it up to them then and see if they'll possibly cover just replacing anything that needs it.
Thanks
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 40
Mileage: 69232 km
Time Indication: 0
Date: 2013.04.11
Time: 18:14:59
Freeze Frame:
RPM: 672 /min
Temperature: 66.0°C
Pressure: 3.5 bar
Voltage: 13.67 V
Temperature: 30.0°C
Thanks
I copied the data and saved it. I can print it out and bring it in when I take the car in. Light hasn't come back on in a couple days so it may have been a misread.
Do search on P2294 under my name.
To make a long story short, you need to replace the high pressure fuel pump.
Code takes a while to comeback, but it will.
It seemed to me the light came on stop and go condition.
