Misfire issue P0300, P0301 and P0302
#21
My misfires
I have a 2011 A8L with 95K miles all original equipment, no mods. This winter when warming up the car I started to hear a bit of muffler-type noise as well as a whistling/whine coming from the engine bay. I never opened the hood to check. Just figured it was cold start kind of thing. My CEL has never come on. There has been no perceived degradation in performance. I have an OBD11 which yielded to Log pasted below.
After reading thru this post, reminiscing on how simple issues (but tough to find) can cause other secondary problems as well as having mechanics change parts (which don't fix the problem but you get charged anyway) and watching some YoutTubes from Deutsche Auto Parts
, I suspect that I have a vacuum issue which is causing things to get out of whack.
WDYT ?
OBDeleven data log
Date: 2019-02-13 15:02
VIN: WAURVAFD2BN018706
Car: Audi A8
Year: 2011
Body type: Long
Engine: CDRA 273 kW (371 HP) 4.2 l
Mileage: 153172 KM
01 Engine
System description: 4.2l V8/4V
Software number: 4H0907560C
Software version: 0005
Hardware number: 4H0907560
Hardware version: H07
ODX name: EV_ECM42FSI0114H0907560C
ODX version: 001006
Long coding: 0106000A290F0268
Trouble codes:
P030000 - Random/Multiple Cylinder Misfire Detected
Intermittent
Date: 2019-02-12 13:35:49
Mileage: 152842 km
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Engine speed: 1169.50 1/min
Normed load value: 34.9 %
Vehicle speed: 0 km/h
Coolant temperature: 48 °C
Intake air temperature: 40 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.334 V
Dynamic environmental data: 209627100C01FB110B0000048E11280510FC04A311124210F4 17FB1016030A
P030200 - Cyl.2 Misfire Detected
Intermittent
Date: 2019-02-12 13:36:31
Mileage: 152842 km
Priority: 2
Engine speed: 650.00 1/min
Normed load value: 23.9 %
Coolant temperature: 54 °C
Voltage terminal 30: 14.442 V
Dynamic environmental data: 209627100C00C4110B0000041311280510FC031311124210F4 1194101602E2
WDYT ?
OBDeleven data log
Car: Audi A8
Year: 2011
Body type: Long
Mileage: 153172 KM
01 Engine
ODX version: 001006
Trouble codes:
Intermittent
Mileage: 152842 km
Priority: 2
Intermittent
Mileage: 152842 km
Priority: 2
#22
That’s what I’m looking into right now, had the day off so I changed plugs and cleaned everything up in that area. Tried out the Denso Iridium TT plugs that I had good luck with in the past ($45 on Rock Auto for 8). Was thinking about those NGK laser iridium plugs that were mentioned a few replies up, but these were easier to come by. Runs better, but not great yet. I’ve been leaning towards that PRV/PCV thing lately, started another post involving that. Not sure why I started on that path, but funny you posted that YouTube link, gonna watch it after this. Saw another vid where you pull the oil cap while it’s running and there’s a lot of vacuum created where the oil cap is hard to remove and will get sucked back in, it could point to an issue with that PRV. My exhaust has a little “puff” or pop to it when idling and if I pull that cap the exhaust starts sounding like a cammed out drag car and the car starts shaking, plus sounds like a vacuum cleaner in the oil filler hole. Not getting any codes at the moment, so I’ve come to a bit of an impasse.
#23
I just got my A8L back from a trusted mechanic who did an "****" evaluation of the vacuum lines and manifolds, etc. Found some leaks, fixed them and the car runs like a dream again.
#24
That’s good you found one of those mechanics, they’re the best kind. I’m one of them, but most of my training was on Harleys. Bring one to me and you’ll get a perfect running bike back, lol. Did your guy replace any hard parts, or were they just simple fixes he made work? Was he just doing a once over, service, or did you take it to him for a specific issue? I wonder how he discovered the vacuum system issues, like if it’s a good idea to find someone with a smoke tester or if one is even applicable to these systems.
Tstealth32
20
05-03-2018 05:00 AM
Cole 2.8Q
03-06-2003 11:28 AM
BetterThanVW
08-21-2001 12:00 PM
