MMI failure
MMI failure
]I am looking at a 2006 A6 3.2 Quattro AWD with low mileage for purchase. The MMI has very recently failed. Consequently, the radio and GPS (at least) don't operate. I presume the repair is very expensive and I don't need either. My question is would the failing of the MMI deny me access to things other than the GPS and radio? i.e. are there other functions which are inaccessible, or non-working, except through the MMI?
Thanks
Thanks
Worst-case scenario, liquid was spilled sometime/or multiple times over the car's life and fried the electronics inside. Check ALL the buttons and make sure none are sticky.
Honestly, the MMI is half the car in my opinion. You will basically have no function of any kind on the car, except driving/braking, a BIG drawback in a car like this. If the entire unit must be replaced, yes, it will be VERY expensive. I personally wouldn't risk it, and I would definitely not live with a C6 that way.
Keep searching for another car, there will always be another. I learned that lesson hard. The C6 cars are pretty damn solid and reliable, but you cannot buy one which has components as important as these, broken. This is also a signal that there could be OTHER things wrong with the car.
Good luck. Do research. Think it through.
Yeah, the repair might be $300 and it could be something far worse. Hard to guess at stuff like this...
I purchased my A6 and the MMI wasn't working as well. However all the other electronics are working. In the glove box the CD changer lights up, the DVD player doesn't. In the trunk, the NAV lights up as well. Not sure if the amp is good or not. Having it checked out today. Will update you guys as to my results
awdinut
01-19-2017 08:03 PM
maseto2003
08-26-2005 08:35 PM
