MMI Not working - Startup Fault
#21
latest update: my local indie mechanic was able to pass my MMI Control Head and then MMI Button Unit to an unknown local who was able to test them. The Control Head came back OK, but I was told the Button Unit was dead. So my next move is to do one of these swaps
https://www.ebay.com/sch/i.html?_fro...3AA6%2BQuattro
Has anyone done this before -- are the boards all the same?
#23
Final update: The MMI controller board was dead and a quick replacement on eBay brought my MMI back to life!
It was my first guess, but I didn't want to start replacing parts blindly. However, the 4 MMI loopback connectors I ordered on eBay never arrived, so I sort of reverted to old habits...
#24
My question is did you diagnose the reason why water entered in the car? Did it happened again? Is not much help fixing the problem if the main trouble is still there...
#25
driver side mirror
I've been following this thread and wondering if the MMI could be related to water leaking in the driver side mirror. I had someone hit my mirror and it came apart in two pieces but i was able to snap it back together although one of the 'teeth' didn't close all the way so there is a bit of a gap in the mirror separating. The blinker and lights on the mirror all work fine though so i have not gotten it fixed as it was not a huge deal. This happened end of November and now in early February my MMI did a weird flash/glitch on the screen and shortly after was not working. Now reading these posts and hearing about wire problems with the driver mirror and water damage inside the front driver area i'm wondering if its related. The interesting thing though is when i took it to my dealer they did scans and couldn't figure out why it wasn't working so summed it up to a tech problem but had to order in a new console/piece of the MMI. I would think it if was related to the driver mirror having that gap it would of shown that as a fault? I guess what i'm wondering now, should i spend the money to get the driver side mirror fixed in case of this being a problem for water leak leading to MMI damage ? or is it unrelated? any thoughts?
#26
Check MY comments here: https://www.audiworld.com/forums/a6-...blems-2963758/
#27
But in your case it is possible that some kind of short is causing trouble... In my case computer diagnostic was not of much help...
WallyAnderson
A4 (B9 Platform) Discussion
10-17-2018 07:32 PM
