A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
wheel bearing emergency help!
Old 10-06-2013, 09:10 AM
kmongru's Avatar
Default wheel bearing emergency help!
I have an 05 a6 3.2. Was working on the wheel bearing, and the bearing itself came out but the housing is stuck in the knuckle??!!!!! Anyone have any tips or suggestions??? Let me know please!
Old 10-08-2013, 11:35 PM
z06psi's Avatar
The only trick I know with the race still in there is to take off the knuckle, bend a large straight screw driver to be able to knock it out from the inside.
Old 10-09-2013, 02:46 AM
kingfishgrapejam's Avatar
Is there enough lip to get a jawstyle gear puller puller on or in it?
Old 10-09-2013, 03:37 AM
Senior Member
Catamount90's Avatar
Default Do you have a HF nearby?
Do you have a Horror Freight in the area? If so, this thing will do the job. Otherwise, I'd pull the knuckle. How were you going to press the new bearing in?
http://www.harborfreight.com/fwd-fro...ers-66829.html
Old 10-09-2013, 08:22 AM
kmongru's Avatar
theres not alot of lip. I even ended up cutting it as much as I could and it still would not budge. I am thinking about heating it. The new bearing doesnt press into this, it just bolts on. It presses only into the hub. Unless im waaay out to lunch and it does? haha
Old 10-09-2013, 10:16 AM
Senior Member
Attachment 34509
Okay I just googled the wheel bearing for our cars. It's all one piece and bolts up without any pressing in -- that's cool! I thought this was a basic press-the-bearing-in job but the integrated housing certainly makes things easier.
So now you have to get the housing out... Hmm.
I just looked up the DIY on this job and you DID remove the housing bolts (from the backside) first already... ...right? (Sorry if this is a dumb question)
http://www.audizine.com/forum/showth...ng-replacement
Old 10-09-2013, 01:49 PM
Work the around the flange with an air chisel?
Old 10-10-2013, 06:21 AM
newa6er's Avatar
did you try whacking it sideways with a big hammer. yes, seriously you should be able to rotate the bearing housing by striking it in a rotational direction. this should loosen it, if it only turn a little bit you might be able to use the threads of the housing to screw a bolt against the knuckle
Old 10-10-2013, 08:18 AM
kmongru's Avatar
yes all the bolts etc are removed.
I've tried hitting this thing from every direction and its have not even moved a milimeter. I took an air hammer to it last night, and nothing. It wont rotate for the life of me, but I may try again.
its been going on since last fri night!! I'm almost debating buying a new knuckle
Old 10-10-2013, 02:52 PM
hrc4u's Avatar
Tried heat torch around it?
Quick Reply: wheel bearing emergency help!
