Newly (self) painted door blades
I'm kinda proud of myself and wanted to share my success with everyone. The door blades at the bottom of my doors are separating from rain getting in there and causing rust which causes it to separate. So, I went to the junkyard and found 3 (couldn't find one for the driver's door yet) and paid a whopping $19 or so dollars for all three. My car is silver and these were blue. I need to point out that I have ZERO experience with painting. I got some primer from Lowes, ordered some color match paint and got a spray bottle of 2K clear coat, a small bottle of prep solvent, a roll of blue painter's tape, a tack rag and a variety of sandpaper. I watched a ton of youtube videos and set everything up in my garage this past weekend and gave it a shot. I think the results (color match, finish and fitment) are OUTSTANDING. I really wish I had the 4th one and did them all at once because it was a tedious and time consuming process and it will be hard for me to repeat just for the one piece.
Let me know what you think.
old (original) ones on the car and replacements on the ground
Products I used (awesome stuff)
original, replacement and replacement after sanding
Sanding in progress
Sanding
Primer
Primer
Base (color) coat
Final base (color) coat
After clear coat (still wet)
Driver rear door BEFORE
Driver rear door AFTER
Passenger rear door BEFORE
Passenger rear door AFTER
Passenger front door BEFORE
Passenger front door AFTER
Space between passenger front and rear doors BEFORE
Space between passenger front and rear doors AFTER
Passenger side profile AFTER
Sanding in progress
Sanding
Primer
Primer
Base (color) coat
Aking, they look damn good! Is the silver color match really that good?
What happened with your wheel re-finishing project? Can we see?
Fun? Not sure I would call it fun. LOL. But it wasn't too bad. Just time consuming due to the multiple coats of each product and the wait times between each coat as well as the extended wait times between each product. How does it look to you KevinGary?
I didn't paint the rims. I am taking beep beep's recommendation and reading a book instead. LOL. Nah, I just figured that the juice wasn't worth the squeeze. The rims really aren't that bad unless you are down there staring at them. However, now that I have 1/2 a can of the color match paint (which I think will look good on the rims) and another full can of the 2k clear coat, I might just rethink that. We will see. It's not a priority right now though because I am giving serious thought to manual carbon cleaning, driver side chain tensioner, oil filter housing gasket and valve cover gaskets.
That looks great. Like you experienced, quality painting is all about the prep. The painting itself goes super quick. Where in VA are you? Reason I ask is I had this with my 2005 (RIP due to deer), I could not find any A6s in any pick a parts near me in Northern VA. I know all the pick a part places since I have 2 old Jeep Cherokees (98 and 99). I never saw any A6s in any of the 3 places I went to regularly. I have a 2008 now, but always on the look out for what pick a parts have C6 A6s.
I can’t give you my spot then you will take all the good stuff from them I need LOL.
Just joking. Fredericksburg, Va. The one in the Massaponax area normally has 2-4 of them. And they rotate the stock too. Weird.
Where are you?
Where are you?
They look good. Nice job.
