No Vrooom Vrooommm from my 06 A6 4.2 - Crosspost from Audizine
So night before last, got home, just like always, parked the car, got out, ate dinner went to bed. No big deal
Yesterday, we to go to work, the car was basically dead. The MMI came on, Radio BT, steering wheel adjustment, seat adjustment and a few other things worked, Nothing Else.
There is no Click from the break pedal to release the shift lever, no clicks from the engine, really, just a dead car.
VCDS starts out as follows
______
Thursday,28,February,2019,11:45:24:59453
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 65 67 72 76 77
Mileage: 189690km-117867miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100 ***
01-Engine -- Status: Cannot be reached 1100 ***
02-Auto Trans -- Status: Cannot be reached 1100 ***
03-ABS Brakes -- Status: Cannot be reached 1100 ***
05-Acc/Start Auth. -- Status: Malfunction 0010 ***
07-Control Head -- Status: Malfunction 0010 ***
08-Auto HVAC -- Status: Malfunction 0010 ***
09-Cent. Elect. -- Status: Malfunction 0010 ***
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010 ***
15-Airbags -- Status: Cannot be reached 1100 ***
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010 ***
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010 ***
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Cannot be reached 1100 ***
55-Headlight Range -- Status: Cannot be reached 1100 ***
56-Radio -- Status: OK 0000 ***
61-Battery Regul. -- Status: Malfunction 0010 ***
62-Door, Rear Left -- Status: Malfunction 0010 ***
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010 ***
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
_____
I am trying to figure out where to start with the items that "Cannot be reached"
Or is that where to start at all?
_____
Response to the "Have you checked the battery" Question
Battery is strong enough to crank if the juice was getting that far. It seems to be more than just a no Crank. Most of the systems are off line.
I have checked all of the fuses I know of, the 2 boxes on either side of the dash, and the right side of the trunk.
I can not move the gear selector lever, as the systems that release that when the break is pushed are not working. The MMI screen will come on and play music. But the DID Driver Info Display between the gauges does not come on. If I try and move the gear selector out of Park, the center display will give the warning that if it is not in park, strange things will happen, so that switch seems to be working. This is a very dead car. windows do not operate, seats and steering wheel adjustments do, but it does not unlock. The same results using either the key or the push Button.
At this point, I do not think the majors systems are getting juice.
______
www.Ross-Tech.com
Chassis Type: 4F0
Address 01: Engine
Cannot be reached
Cannot be reached
_____
_____
Your codes tell you that the only main malfunctions you have is auth/immo related. All others are...cannot be reached...which means they are not powered since there is a power break from immo module further on..
At this moment..maybe the cheapest option is to buy xtool vag401 scanner as i explained in earlier posts how to reset immo using this scanner..if thats the problem..then you can buy new steering column or use that scanner when / if immo module acts up again...
what does fault say in those modules that says malfunction? you can reach them?
post full autoscan log here!
/H
/H
Hate posting the whole log, but Don't see a way to make it a scrollable window.
Wondering if this a J518 module issue, hope not.
Ross-Tech: Home
Chassis Type: 4F0
Address 01: Engine
Cannot be reached
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0180
Revision: 30070501 Serial number: 10600600254140
Coding: 0000015
Shop #: WSC 02323 785 00200
VCID: 6390A7CB775B3BCFE3F-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0070
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
3 Faults Found:
00193 - Rear Right Door Handle Touch Sensor (G418)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 6
Reset counter: 143
Mileage: 0 km
Time Indication: 0
00288 - Steering Column Lock Actuator (N360)
014 - Defective
Freeze Frame:
Fault Status: 01111110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 146
Mileage: 189698 km
Time Indication: 0
Date: 2019.02.28
Time: 09:54:10
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 186
Mileage: 189698 km
Time Indication: 0
Date: 2019.02.28
Time: 10:24:20
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 303JN057509036
Coding: 0000003
VCID: 313C1D837D27D95F213-8064
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H08 0050
Subsystem 2 - Serial number: 00000000251178
Subsystem 3 - Serial number: 0111.10.050000000100011058ÿ
Subsystem 4 - Serial number: 011058ÿ
1 Fault Found:
00658 - Control Head
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Time Indication: 15
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000000193154
Coding: 0000040
Shop #: WSC 02325 785 00200
VCID: 5BE09F2B4F2B030FABF-800E
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 C HW: 4F0 907 279 A
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0114123
Shop #: WSC 02335 785 00200
VCID: 290CF5E355F7A19FE93-807C
Subsystem 1 - Component: Fehler Lin-Slave 01
Subsystem 2 - Component: Fehler Lin-Slave 02
1 Fault Found:
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01111010
Fault Priority: 2
Fault Frequency: 31
Reset counter: 146
Mileage: 189128 km
Time Indication: 0
Date: 2019.02.05
Time: 17:40:00
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 2708F3DB4FE397EFFF7-8072
No fault code found.
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7E3016865
Shop #: WSC 00000 000 00000
VCID: 280AF0E74EFD9897F6D-807C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 92
Mileage: 188434 km
Time Indication: 0
Date: 2005.09.20
Time: 15:41:24
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90054052720335
Coding: 0012041
VCID: 6696BEDF84694EE7041-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 980 N
Component: KOMBIINSTR. M73 H16 0660
Revision: 00200000 Serial number: 4PY39TDA5
Coding: 2129263
Shop #: WSC 51539 001 104857
VCID: 211CEDC32DC769DFB13-8074
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300805A14812E
Coding: ECFE73CD1B7904
Shop #: WSC 02334 785 00200
VCID: 2708F3DB43E397EFFF7-8072
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619CADC36D4729DFF13-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H45 0740
Revision: 00000000 Serial number: 355JR057555410
VCID: 382A20A79E5D081766D-806C
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000808538
Coding: 0000056
VCID: 2514F9D339EF85FFCDB-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000008869
Coding: 0012114
VCID: 5EE6963F5C391627CC1-800A
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake
Cannot be reached
Address 55: Headlight Range
Cannot be reached
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394J$057625880
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000135281
Shop #: WSC 00000 384 00290
VCID: 2310E7CB37DB7BCFA3F-8076
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 1510100323
Coding: 344630393135313035442056413031353130313030333233
5 Faults Found:
02277 - Quiescent Current Stage 6
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 188473 km
Time Indication: 0
Date: 2019.01.22
Time: 12:13:40
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 188473 km
Time Indication: 0
Date: 2019.01.22
Time: 11:52:52
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 188473 km
Time Indication: 0
Date: 2019.01.22
Time: 12:13:10
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 188473 km
Time Indication: 0
Date: 2019.01.22
Time: 12:13:20
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 188473 km
Time Indication: 0
Date: 2019.01.22
Time: 12:13:30
Address 62: Door, Rear Left
Cannot be reached
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 HW: 4F0 907 273
Component: Reifendruck 3 H04 0080
Revision: 00040080 Serial number: 00000700011464
Coding: 0042729
Shop #: WSC 00226 113 74688
VCID: 609AA8C7664D20D7FED-8034
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000510120055
Shop #: WSC 12336 024 394758
VCID: 343214978235EC774A5-8060
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0030
Revision: 00H09000 Serial number: 11720527800729
Coding: 0201206
Shop #: WSC 12345 102 209715
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H11 1130
Revision: 00000000 Serial number: 00000007520103
Coding: 0010900
End----(Elapsed Time: 01:36, VBatt start/end: 11.9V/11.9V. VIgn 0.0V)------
Ross-Tech: Home
Chassis Type: 4F0
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000015
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 143
Mileage: 0 km
Time Indication: 0
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 146
Mileage: 189698 km
Time Indication: 0
Date: 2019.02.28
Time: 09:54:10
00955 - Key 1
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 186
Mileage: 189698 km
Time Indication: 0
Date: 2019.02.28
Time: 10:24:20
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Time Indication: 15
Coding: 0000040
1 Fault Found:
Coding: 0114123
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Reset counter: 146
Mileage: 189128 km
Time Indication: 0
Date: 2019.02.05
Time: 17:40:00
Revision: 00000000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 92
Mileage: 188434 km
Time Indication: 0
Date: 2005.09.20
Time: 15:41:24
Address 15: Airbags
Cannot be reached
Coding: 0012041
Coding: 2129263
Coding: 0082954
Cannot be reached
Cannot be reached
Coding: 0000056
Coding: 0012114
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000002
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 188473 km
Time Indication: 0
Date: 2019.01.22
Time: 12:13:40
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 188473 km
Time Indication: 0
Date: 2019.01.22
Time: 11:52:52
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 188473 km
Time Indication: 0
Date: 2019.01.22
Time: 12:13:10
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 188473 km
Time Indication: 0
Date: 2019.01.22
Time: 12:13:20
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 188473 km
Time Indication: 0
Date: 2019.01.22
Time: 12:13:30
Cannot be reached
Coding: 0042729
Cannot be reached
Coding: 0201206
Coding: 0010900
doesnt allow to post the file as attacment? txt? =)
well...this one isnt probably to good:
"00288 - Steering Column Lock Actuator (N360)
014 - Defective"
will look more in my elsawin later...but installing other stuff on that computer right now
014 - Defective"
Well, It is alive!!!! and going Vrooooooooooommmmmmmmm Vroooooooooooooooooooommmmmmmmmmmmmmm
just cleared the codes on
The steering wheel unlocked and it came to life.
sooooo Strange.
sooooo Strange.
