A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Oil leak issue with 2005 Audi A6
Old 05-21-2017, 04:47 PM
bballfreak's Avatar
Default Oil leak issue with 2005 Audi A6
I have replaced the valve cover gaskets 4 times in 7 months and also replaced the valve covers also.
They have properly installed.
I see oil inside all the spark plugs.
A friend of mine is a BMW/Mercedes mechanic is trying to figure out why is this happening,
He was suggesting to get another oil cap, drill a hole and measure the crankcase pressure
thinking there is some restriction somewhere.
Am looking for some guidance for possibilities as to what is wrong??
Thks
Old 05-21-2017, 10:24 PM
A6Gary's Avatar
From your descriptions, I think your crankcase is being over pressurized, which is blowing oil pass the gaskets. I would go with your friends suggestion to see if that is the case.
Old 05-22-2017, 05:47 AM
bballfreak's Avatar
I ordered the crankcase vent valve, just to see if that helps while my mechanic friend is getting a oil cap for that car, drill a hole and measure the pressure.
Old 05-22-2017, 11:14 AM
beep-beep's Avatar
do you have normally aspirated 3.2 or supercharged 3.0T engine?
Old 05-22-2017, 11:31 AM
bballfreak's Avatar
It's normally aspirated
3.2 v6. BKH engine
Old 07-16-2017, 09:43 AM
Audishiva's Avatar
3.2 v6. BKH engine
Any resolution to this issue? I have the same engine and a lot of oil in the spark plug wells causing misfires. I have do the VCG to no success.
Old 07-16-2017, 06:28 PM
bballfreak's Avatar
Default Oil leak
i realized the valve stems are leaking oil
so I added a sealant around the valve cover gasket
and added Lucas oil additive to reduce the oil leak.
eventually, have to take the engine apart and fix this properly but have much less oil drops.
lets see how it goes
old96A4
30
01-29-2023 10:02 AM
Mike141
03-01-2014 05:07 AM
tommo2
10
02-18-2013 07:41 AM
cranberryjello
10-20-2010 02:58 AM
archeroc
01-04-2009 01:03 PM
Quick Reply: Oil leak issue with 2005 Audi A6
