P0346 :: Camshaft position sensor
Hi Folks!
My car will only shift once I let off the throttle. I'm getting a DTC P0346 :: Camshaft Position Sensor ”A” Circuit. Range/Performance (Bank 2). If I'm not mistaken, I believe there are 4 of these sensors. Can someone please tell me which one this is so I don't have to play guess and check. I have a 2005 A6 3.2L Q. Greatly appreciated. |
It's not a sensor problem, you're timing is off. Do you have rattle sound on cold start? misfires?
If you are getting diesel engine like sound at start and misfires, you most likely have a bad cam tensioner. I had similar symptoms and it ended up being the cam tesioner which is more common on earlier version of our cars.
There are four hydraulic control solenoids for camshaft adjustments (two for each bank). I would swap the bank 2 (driver side) solenoids, clear the fault code then go from there. You can see solenoids on engine valve covers at cylinder 3 and 6 areas.
Originally Posted by oaktreelimb
(Post 24278430)
2 lozts
You need to timing advance/retard...In VCDS-> Engine->Channel 93> Camshaft adjusters rotation angle should be between -10° to +10°, if more, you need to change 2 tensioners and 2 upper chains... P.s. in MY 2005-2006 it's common problem on 3.2FSI engine and 2.4 BDW (Europe). In MY2007 the tensioners were redesigned. |
You need to check numbers two times on Cold start and when engine is warm.
Originally Posted by va-parts
(Post 24278180)
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl Part No SW: 4F1 910 559 B HW: 4F1 907 559 A Component: 3.2l V6 FSI 0050 Revision: --H15--- Serial number: Coding: 01050106190F0120 Shop #: WSC 02325 785 00200 VCID: 2A50875EFC97 1 Fault Found: 16730 - Camshaft Position Sensor (G163): Implausible Signal P0346 - 006 - Short to Plus Freeze Frame: Fault Status: 01000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 40 Mileage: 156116 km Time Indication: 0 Date: 2012.03.25 Time: 16:10:21 Freeze Frame: RPM: 1280 /min Mass Air / Rev.: 196.2 mg/str Temperature: 39.0°C Idle Bin. Bits: 00010000 Speed: 0.0 km/h Readiness: 0110 0101 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 E HW: 4E0 035 111 A Component: CD-Changer H44 0430 Revision: 00000000 Serial number: AUZ5ZBE7120686 Shop #: WSC 00000 000 00000 VCID: 1B3E529AA3CD 1 Fault Found: 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 4 Fault Frequency: 2 Reset counter: 31 Mileage: 155234 km Time Indication: 0 Date: 2012.03.15 Time: 09:02:15 ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl Part No SW: 4E0 910 593 B HW: 4E0 035 593 Component: SDAR Serial number: AUZ4Z7D3007298 Shop #: WSC 00000 000 00000 VCID: 2648736EE88F 1 Fault Found: 02635 - Tuner Not Enabled/Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 227 Mileage: 154315 km Time Indication: 0 Date: 2012.03.04 Time: 13:50:53 ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 887 K HW: 4E0 919 887 C Component: MNS US H44 0570 Revision: 00000000 Serial number: 378BV057516528 Shop #: WSC 02327 785 00200 VCID: 356AA4222529 1 Fault Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 5 Fault Frequency: 1 Reset counter: 0 Mileage: 154315 km Time Indication: 0 Date: 2012.03.04 Time: 14:13:27 Freeze Frame: Bin. Bits: 0100 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 E HW: 4F0 907 289 E Component: Komfortgeraet H15 0100 Revision: 01000015 Serial number: 01002712740000 Coding: 0423997 Shop #: WSC 02335 785 00200 VCID: 2C5C8146F663 Part No: 1K0 951 605 C Component: LIN BACKUP HORN H02 1301 2 Faults Found: 01503 - Bulb for 3rd Brake Light (M25) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 12 Mileage: 145286 km Time Indication: 0 Date: 2011.11.08 Time: 08:47:33 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.lbl Part No SW: 4F0 910 801 HW: 4F0 907 801 Component: EPB C63C0030 H03 0030 Revision: C63C0030 Coding: 0005022 Shop #: WSC 02334 785 00200 VCID: DDBA9C827D59 1 Fault Found: 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 38 Reset counter: 47 Mileage: 154312 km Time Indication: 0 Date: 2012.03.04 Time: 14:39:17 Freeze Frame: Voltage: 13.25 V Count: 236 |
(Post 24278539)
2 lozts
