Parking brake/ABS harness replacement
Has any one replaced their harness for the parking brake motor? It has a plug that connects to the ABS module as well. Since I had gotten an error code for ABS as well, I'm thinking the harness is the culprit.
4F0972253L - Rear ABS Wiring Harness - left - ES#393606 Dealer wants $1000 for it - has anyone replaced this as a DIY? I took the side panel on the trunk off; but the wires seem to be going down into the wheel well at that point. Not sure how I can access the wires there. |
Originally Posted by am_ver
(Post 24589707)
Did you already check the continuity of the wires through the harness already?
I think you guys might be right about the control module being the issue. I've ordered the module which comes in Monday - replacing that is a breeze. If that doesn't fix the issue then it has to be the harness (I already tested the motor and that is working fine).
Originally Posted by milan_o
(Post 24589938)
Update:
Picked up the control module from the dealer today. Replaced the old one out; put the connector onto the motor (without bolting on the motor to the caliper). Turn the ignition on - the bad red circular malfunction is gone. Turn the parking brake and I see the motor is turning. I'm like - yeah, it was the control module. Bolt the motor onto the caliper. Turn the key, and the red bad circular error code is back.... on the right parking brake works - no life on the left. the obvious thought is that the connector is loose - so connect that multiple times; but no luck. Take the motor off the caliper and try to see if bolting it on caused the issue - Nope, still doesn't work. Plugged it in once again - then tried basic adaptation (010) - but nothing happened. Nether of the motors moved. Error codes below if anyone has ideas VCDS Version: Release 805.1 Data version: 20080823 Monday,28,July,2014,19:43:30:26365 Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53 55 56 61 62 65 72 77 VIN: WAUDH74F86N095885 Mileage: 197880km/122956miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 36-Seat Mem. Drvr -- Status: Malfunction 0010 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 1010 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door,Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl Part No SW: 4F2 910 559 B HW: 4F1 907 559 A Component: 3.2l V6 FSI 0030 Revision: --H15--- Serial number: Coding: 01050109190F0120 Shop #: WSC 26153 444 84168 No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F2 910 156 D HW: 09L 927 156 A Component: AG6 09L 3.2 FSI USA 0030 Revision: --H01--- Serial number: 4095291 Coding: 0000002 Shop #: WSC 26118 444 53996 1 Fault Found 049448 - No Communications with Parking Brake Control Module U0128 - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Mileage: 197880 km Time Indication: 0 Date: 2014.07.24 Time: 09:17:41 Freeze Frame: RPM: 1280 /min RPM: 864 /min RPM: 0 /min (no units): 30.0 (no units): 32.0 Temperature: 16.0°C T.B. Angle: 0.0° ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 L HW: 4F0 614 517 L Component: ESP 8.0 quattro H04 0090 Revision: 00000000 Serial number: 00000000000000 Coding: 0020895 Shop #: WSC 02325 785 00200 1 Fault Found 00473 - Control Module for Elect. Park/Hand Brake (J540) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 8 Reset counter: 40 Mileage: 197880 km Time Indication: 0 Date: 2014.07.24 Time: 09:34:36 Freeze Frame: Hex Value: 0x00C0 Hex Value: 0x40A2 Hex Value: 0x002D Hex Value: 0x05AA Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0180 Revision: 30070501 Serial number: 10600600253886 Coding: 0000011 Shop #: WSC 02323 785 00200 Part No: 4F0 910 131 J Component: FBSAUDIC6 EZS H45 0070 Part No: 4F0 910 220 A Component: FBSAUDIC6 IDG H39 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl Part No SW: 4F0 910 732 Q HW: 4E0 035 729 Component: Interfacebox H43 4610 Revision: 00000000 Serial number: 303JJ057509140 Coding: 0000003 Shop #: WSC 26118 444 53996 Part No: 4F0 910 609 E Component: Bedienteil MMIC6H08 0050 1 Fault Found 02259 - Information Display and Control Head (Front) (J685) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 40 Mileage: 197880 km Time Indication: 0 Date: 2014.07.28 Time: 17:36:55 Freeze Frame: Bin. Bits: 0000001 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F1 820 043 S Component: KLIMABETAETIGUNGH12 0160 Revision: 00000027 Serial number: 00000000193333 Coding: 0532518 Shop #: WSC 26118 444 53996 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 D HW: 4F0 907 279 Component: ILM Fahrer H15 0190 Revision: 00000000 Serial number: 4F0907279 Coding: 0014123 Shop #: WSC 02335 785 00200 Part No: 4F1 910 113 Component: Wischer AudiC6 H05 0150 Coding: 00062736 Shop #: WSC 02335 Part No: 4E0 910 557 Component: REGENLICHTSENSORH10 0050 Coding: 00141886 Shop #: WSC 02335 1 Fault Found 01494 - Bulb for Parking Lamps; Left (M1) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 1 Mileage: 164344 km Time Indication: 0 Date: 2013.04.05 Time: 18:14:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBE7257018 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655.lbl Part No SW: 4F0 910 655 F HW: 4F0 959 655 A Component: 66 AIRBAG AUDI8RH29 0270 Revision: 12H29000 Serial number: 00359D0A554B Coding: 0013878 Shop #: WSC 02325 785 00200 Part No: 4F0 910 339 A Component: BF-Gewichtsens. H02 0050 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H07 0230 Revision: 00H07000 Serial number: 90025052810047 Coding: 0002021 Shop #: WSC 02323 785 00200 Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 900 A HW: 4F0 920 950 M Component: KOMBIINSTR. M73 H11 0660 Revision: 00100000 Serial number: 4R87A05A5 Coding: 0083263 Shop #: WSC 26131 444 92477 1 Fault Found 00473 - Control Module for Elect. Park/Hand Brake (J540) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 40 Mileage: 197880 km Time Indication: 0 Date: 2014.07.24 Time: 09:17:41 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 D Component: Gateway H11 0070 Revision: 11 Serial number: 1300805A1481F1 Coding: 6CFE73CD1B3104 Shop #: WSC 26118 444 53996 1 Fault Found 00473 - Control Module for Elect. Park/Hand Brake (J540) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 40 Mileage: 197880 km Time Indication: 0 Date: 2014.07.24 Time: 09:17:41 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4F0 959 760 Component: Sitzmemory FS H04 0050 Revision: 00000000 Serial number: 00000000896400 Coding: 0082946 Shop #: WSC 02334 785 00200 1 Fault Found 01336 - Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 39 Mileage: 197880 km Time Indication: 0 Date: 2014.07.20 Time: 18:28:35 ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 M HW: 4E0 919 887 L Component: MNS US H48 1100 Revision: 00000000 Serial number: 313CP077519536 Shop #: WSC 31414 790 00001 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 793 E Component: TSG FA H12 0080 Revision: 00000000 Serial number: ™6 Coding: 0035563 Shop #: WSC 02327 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 G HW: 4F0 907 289 G Component: Komfortgeraet H19 0140 Revision: 01400019 Serial number: 01007951410000 Coding: 4619325 Shop #: WSC 02335 785 00200 Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4F0-910-223-BO.lbl Part No SW: 4F0 910 223 J HW: 4F0 035 223 G Component: DSP-High C6 H09 0240 Revision: PROD_01 Serial number: 00000000809141 Coding: 0000016 Shop #: WSC 02323 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 B Component: ILM Beifahrer H10 0080 Revision: Serial number: 00000000008390 Coding: 0002114 Shop #: WSC 02323 785 00200 No fault code found. |
Monday,28,July,2014,19:23:33:26365
VCDS Version: Release 805.1 Address 53: Parking Brake Control Module Part Number: 4F0 910 801 D Component and/or Version: EPB CEFC0090 H05 0090 Software Coding: 0000000 Work Shop Code: WSC 00001 5 Faults Found 02432 - Supply Voltage for Left Parking Brake Motor (V282) 011 - Open Circuit - MIL ON Freeze Frame Fault Status: 11101011 Fault Priority: 1 Fault Frequency: 10 Reset counter: 0 Mileage: 197880 km Time Indication: 0 Date: 2014.07.28 Time: 18:00:49 Freeze Frame Voltage: 13.46 V Count: 102 02426 - Brake Disk Left Rear; Not Reached 000 - - - Intermittent Freeze Frame Fault Status: 00110000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 40 Mileage: 197880 km Time Indication: 0 Date: 2014.07.28 Time: 17:37:57 Freeze Frame Voltage: 11.90 V Count: 12 02433 - Supply Voltage for Right Parking Brake Motor (V283) 011 - Open Circuit - Intermittent Freeze Frame Fault Status: 00111011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 40 Time Indication: 0 Freeze Frame Voltage: 11.08 V Count: 117 02443 - Control Head 012 - Electrical Fault in Circuit - Intermittent Freeze Frame Fault Status: 00111100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 40 Time Indication: 0 Freeze Frame Voltage: 11.08 V Count: 40 01087 - Basic Setting Not Performed 000 - - - MIL ON Freeze Frame Fault Status: 11100000 Fault Priority: 4 Fault Frequency: 7 Reset counter: 0 Mileage: 197880 km Time Indication: 0 Date: 2014.07.28 Time: 18:11:25 Freeze Frame Voltage: 11.59 V Count: 170 |
