Parking Brake Not Working
Hello,
i changed my switch for eletronic parking brake, then, the parking brake worked intermitent.
Then, i needed to remove center console again to change my cup holder, then, my parking brake didn't work at all, neither the light on the switch.
The wiring is to tight on the parking brake, i think it's damaged.
My VCDS codes are below, if anyone can help me, i appreciate!
"Saturday,23,February,2019,10:57:04:53651
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.4.2
Data version: 20161129 DS267.0
Ross-Tech: Home
VIN: WAUDL74F15N089147 License Plate:
Mileage: 145960km-90695mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 36 42 46 47 4F 52 53
55 56 61 62 72 76
VIN: WAUDL74F15N089147 Mileage: 145960km-90695miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 560 F HW: 4F0 907 559
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number:
Coding: 0027772
Shop #: WSC 02335 785 00200
VCID: 254197B1EC30956A9A-8070
1 Fault Found:
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 G HW: 09L 927 156
Component: AG6 09L 4.2L5V RdW 0070
Revision: --H01--- Serial number: 0082036
Coding: 0001001
Shop #: WSC 04574 659 06332
VCID: 285F9E859B228802A1-807C
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H05 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0021352
VCID: 2D516F91B4C0AD2A52-8078
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 41
Mileage: 145963 km
Time Indication: 0
Date: 2005.02.20
Time: 09:55:27
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4282
Hex Value: 0x0035
Hex Value: 0x01AC
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0160
Revision: 27100401 Serial number: 10600300100347
Coding: 0000007
Shop #: WSC 00197 659 10341
VCID: 63C5C9A9A2842B5AB4-8036
Subsystem 1 - Part No: 4F0 910 131 Q
Component: FBSAUDIC6 EZS H43 0070
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H25 0070
Subsystem 3 - Part No: 4F0 910 220 J
Component: FBSAUDIC6 IDG H01 0060
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory BFS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0070752
Shop #: WSC 04008 758 999999
VCID: 61C9C3A1B898394AA6-8034
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350LY047557365
Coding: 0000007
Subsystem 1 - Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
Subsystem 2 - Serial number: 00000000091513
Subsystem 3 - Serial number: 0109.12.040000000100010900ÿ
Subsystem 4 - Serial number: 010900ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 H
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000024 Serial number: 00000000098124
Coding: 0008264
VCID: 5BB5F1499AF4139AFC-800E
2 Faults Found:
00018 - Motor for Cold-Air Flap (V197)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 145963 km
Time Indication: 0
Date: 2005.02.20
Time: 09:47:59
Freeze Frame:
Voltage: 14.00 V
Temperature: 29.0°C
(no units): 159.0
(no units): 123.0
Temperature: 0.0°C
00739 - Coolant Circulation Pump (V50)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 145963 km
Time Indication: 0
Date: 2005.02.20
Time: 09:48:03
Freeze Frame:
Temperature: 44.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 A HW: 4F0 907 279 A
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0113101
VCID: 275D9DB9963C877AA8-8072
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
1 Fault Found:
01500 - Bulb for Fog-Lamps; Right (L23)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 145960 km
Time Indication: 0
Date: 2005.02.20
Time: 09:50:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD6040855
Shop #: WSC 00000 000 00000
VCID: 1C37B255DF7A54A235-8048
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
Component: 32 AIRBAG AUDI8RH29 0250
Revision: 05H29000 Serial number: 0037LD052W2%
Coding: 0013106
Subsystem 1 - Serial number: 6332CSME084B3E607
Subsystem 2 - Serial number: 6342CSME084B437A9
Subsystem 3 - Serial number: 6351HSME057D461AD
Subsystem 4 - Serial number: 6361HSME055A01571
Subsystem 5 - Serial number: 6371VSME0528172FN
Subsystem 6 - Serial number: 6381VSME0535170EJ
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026050070358
Coding: 0012141
VCID: 66C3D0BD51B65E7253-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 900 R
Component: KOMBIINSTR. M73 H10 0630
Revision: 00200000 Serial number: 4R6747GD4
Coding: 0065143
VCID: 1E33B85DC96646B2DB-804A
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 40
Mileage: 145963 km
Time Indication: 0
Date: 2005.02.20
Time: 09:48:00
Address 19: CAN Gateway Labels: 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 0800804C160095
Coding: ECFE73DC1B0104
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H04 0050
Coding: 0066666
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: y)9
Coding: 0017130
VCID: 29599B818028B10ABE-807C
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01002173590000
Coding: 0402681
VCID: 2C5762958FDAA42245-8078
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: IRUE No Answer
6 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 40
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.07
Time: 18:03:55
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 4
Reset counter: 200
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.07
Time: 18:03:54
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 3
Reset counter: 40
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.01
Time: 12:02:06
02071 - Local Databus
Freeze Frame:
Fault Priority: 3
Reset counter: 40
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.01
Time: 12:02:06
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 80
Reset counter: 200
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.02
Time: 10:30:56
01502 - Bulb for Rear Fog; Left (L46)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 145944 km
Time Indication: 0
Date: 2005.02.01
Time: 15:04:47
Address 47: Sound System Labels: None
Part No SW: 4F5 910 223 F HW: 4F5 035 223 E
Component: DSP-High C6 H14 0330
Revision: PROD_01 Serial number: 00000000020068
Coding: 0000016
VCID: 264390BD91369E7293-8072
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000055084
Coding: 0011114
VCID: 5EB3F85D89E606B29B-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: 9
Coding: 0017130
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0006021
Shop #: WSC 04565 659 97428
VCID: 5DB1FF5184E01DAA82-8008
2 Faults Found:
02442 - Function Lamp in Control Head
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 40
Mileage: 145960 km
Time Indication: 0
Date: 2005.02.19
Time: 17:48:36
Freeze Frame:
Voltage: 11.39 V
Count: 65
02443 - Control Head
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
Voltage: 11.59 V
Count: 40
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Shop #: WSC 02325 785 00200
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: NOSUBSYSTEM
Component: AFS-Modul rechts
2 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 145960 km
Time Indication: 0
Date: 2005.02.20
Time: 09:48:01
02234 - Right Headlight Power Output Stage (J668)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 145960 km
Time Indication: 0
Date: 2005.02.20
Time: 09:48:02
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 352AQ057586147
Coding: 0000001
VCID: 316973E1A8F8C9CA76-8064
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000096168
VCID: 234589A9E2046B5AF4-8076
Subsystem 1 - Part No: 4F0 915 105 B
Component: von MLA 1897022MTM
Coding: 34463039313531303542204D4C41313839373032324D544D
Shop #: WSC 00230 695 91254
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H09 0010
Coding: 0016426
VCID: 2A5B648D852EBA12B7-807E
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H09 0010
Coding: 0016426
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 A HW: 4F0 919 283 A
Component: Parkhilfe 8-Kan H12 0030
Revision: --.--.-- Serial number: 11820434800419
Coding: 0001006
VCID: 224B8CADFD1E6252FF-8076
2 Faults Found:
01543 - Parking Aid Warning Chime (H15)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 145963 km
Time Indication: 0
Date: 2005.02.20
Time: 09:47:58
01625 - Front Parking Aid Warning Chime (H22)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 145963 km
Time Indication: 0
Date: 2005.02.20
Time: 09:47:59
End-------------------------(Elapsed Time: 02:31)--------------------------"
Ross-Tech: Home
55 56 61 62 72 76
Coding: 0027772
1 Fault Found:
Coding: 0001001
Coding: 0021352
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 41
Mileage: 145963 km
Time Indication: 0
Date: 2005.02.20
Time: 09:55:27
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4282
Hex Value: 0x0035
Hex Value: 0x01AC
Hex Value: 0x00FF
Coding: 0000007
Coding: 0070752
Coding: 0000007
Coding: 0008264
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 145963 km
Time Indication: 0
Date: 2005.02.20
Time: 09:47:59
Freeze Frame:
Voltage: 14.00 V
Temperature: 29.0°C
(no units): 159.0
(no units): 123.0
Temperature: 0.0°C
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 145963 km
Time Indication: 0
Date: 2005.02.20
Time: 09:48:03
Freeze Frame:
Temperature: 44.0°C
Coding: 0113101
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 145960 km
Time Indication: 0
Date: 2005.02.20
Time: 09:50:00
Coding: 0013106
Coding: 0012141
Coding: 0065143
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 40
Mileage: 145963 km
Time Indication: 0
Date: 2005.02.20
Time: 09:48:00
Coding: 0066666
Coding: 0017130
Coding: 0402681
6 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 40
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.07
Time: 18:03:55
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 200
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.07
Time: 18:03:54
Freeze Frame:
Fault Priority: 3
Reset counter: 40
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.01
Time: 12:02:06
Freeze Frame:
Fault Priority: 3
Reset counter: 40
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.01
Time: 12:02:06
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 80
Reset counter: 200
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.02
Time: 10:30:56
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 145944 km
Time Indication: 0
Date: 2005.02.01
Time: 15:04:47
Coding: 0000016
Coding: 0011114
Coding: 0017130
Revision: C63C0030
Coding: 0006021
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 40
Mileage: 145960 km
Time Indication: 0
Date: 2005.02.19
Time: 17:48:36
Freeze Frame:
Voltage: 11.39 V
Count: 65
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
Voltage: 11.59 V
Count: 40
Coding: 0000016
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 145960 km
Time Indication: 0
Date: 2005.02.20
Time: 09:48:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 145960 km
Time Indication: 0
Date: 2005.02.20
Time: 09:48:02
Coding: 0000001
Coding: 0016426
Coding: 0016426
Coding: 0001006
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 145963 km
Time Indication: 0
Date: 2005.02.20
Time: 09:47:58
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 145963 km
Time Indication: 0
Date: 2005.02.20
Time: 09:47:59
Fashizzkes84
15
08-14-2019 01:39 PM
N4me
Q7 MKII Discussion
09-12-2017 04:22 AM
iProDrive
11
03-12-2009 07:39 PM
JasonS4+Festicle
12-20-2004 09:28 AM
