Rear Camera Question
I just got delivery of an aftermarket Chinese rear view camera that I picked up on Ebay.
There are 2 white wires that I can't figure out what to do with and there is no documentation about their function in the instructions I received.
Does anyone have any idea what they might be for?
The only thing I can think of is that they possibly turn off the guide lines functionality, but that is a guess based upon some info that I saw other cameras have that ability.
Thanks in advance.
This is the unit I bought.
These are the white wires that I do not know what to do with.
Thanks in advance.
Perhaps they are a power and ground in case you dont have the adapter plug? Youd have to strip it back and see what they splice into. I'd go ahead and hook it up and see if it works as intended and if not worry about them. Perhaps they are for the reverse gear signal or maybe steering signal to make the lines move with the steering wheel like in some of the newer cars. Really hard to guess though.
my car has a trunk release in the handle perhaps they're for the trunk release button
can you send me a link to the seller... I saw it in another thread now I cant find it. I want one.
https://www.audiworld.com/forums/a6-s6-c6-platform-discussion-58/ami-suitable-2958284/
I don't believe there is a steering angle sensor. I was able to wire the camera up and connect it to my TV to test it.
Although I do like the u it and feel it is well made and will install cleanly I am not sure how well the camera is going to do in low light.
I am going to buy one of the cameras that takes the place of a license plate lamp and will test when installing.
I currently live in NYC and garage time is limited, so if I am going to do something that requires disassembly and reassembly I only want to have to do it once so if I have it apart I would like the option to see how another camera might perform.
I did hook up the Chinese unit in my home and was very impressed with the picture in good lighting but the low light performance was not great although I did not factor in the light that would be thrown by the reverse lights.
I ordered all the pieces mentioned to do this upgrade. Will report as to the outcome once done.
Question: How are you guys running the wiring from the camera to the interface, up the passenger side under the carpet, or are you going right up the middle?
I tried to install the camera in my 2006 A6 Avant and hit a snag.
When I ordered the unit there were 2 styles - one for an A6 and one for a Q7 with the difference being where the slot for the switch is.
I ordered the one for the A6 and I believe that is the one that I received -- But I think that the Avant may need to Q7 one.
In the picture you can see the new unit with the camera next to my factory handle. They are actually the same size but the unit with
the camera is propped up.
With the unit out it looks like I should be able to drill a hole where the red mark is and use a surface mounted camera instead.
Any thoughts?
Any thoughts?
