Rear coil spring removal
I found a broken rear spring and started the project. I did a lot of searching on the removal but didn't find much for the C6, only that it was a PINTA to do. I dug into it, removed the shock and found out my spring compressor wouldn't fit. I looked at dropping the subframe but without the proper spring compressor it didn't look like I'd be able to get it out. Can someone give me some suggestions as to what is the right compressor to use, or what else has to be disassembled to get the most clearance to remove the spring?
Thanks
Thanks
Here is what the Bentley Repair Manual states:
Audi > C6 > 2005-2008
Suspension, Wheels, Steering
42 - Removal and Installation.Coil Spring
Note:
To remove and install coil spring, use the procedural description supplied in spring tensioning system VAS 6274.
Note:
ITALSKIER
04-22-2005 03:47 AM
ThirdEye
11-11-2002 09:00 AM
WilsTTer
06-26-2000 11:39 AM
