Go Back  AudiWorld Forums > Audi Models > Audi A6 / S6 / RS 6 > A6 / S6 (C6 Platform) Discussion
Reload this Page >
S6 2007 Car don't move doesn't change gear + water/oil mix in transmission & coolant
A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007-present
Old 04-23-2019, 02:32 PM
Default S6 2007 Car don't move doesn't change gear + water/oil mix in transmission & coolant
S6 2007 Car don't move doesn't change gear + water/oil mix in transmission & coolant.
Guys please help me out here as I'm surrounded by thiefs (Garages/mechanics) and each saying different thing and I know none had ever worked on such vehicle.
THIS IS FIRST TIME I'm fixing it out of dealership. Engine only done 25K mile.
1. TRANSMISSION OIL/WATER MIX
2. ENGINE COOLANT OIL/WATER MIX (HEAT UP)
3. Car doesn't move when shift to Drive or Reverse
What's is required to be fixed and parts I should get
Thank you.
Yasser Al-Luqman is offline
Old 04-23-2019, 02:37 PM
I would suggest going to the dealership.
jeffpuxx is offline
Old 04-23-2019, 03:40 PM
Default I DID AS USUAL
HI Jeff, of course was my first destination but our dealerships not like yours cant explain. They quoted ridiculous amount and only for labor charge was like 3K
Old 04-23-2019, 03:43 PM
What did the dealership say was wrong with the car?
jeffpuxx is offline
Old 04-23-2019, 04:46 PM
This happen to our A6 after a particularly wet trip to a local airport. Small amounts of water got into the transmission through some sort of ventilation system.....whole thing was weird. Transmission was hot yet water did not boil off. Long story short, new transmission was the only fix.
das60 is offline
Old 04-23-2019, 08:26 PM
raj99's Avatar
Thank you.
Yasser Al-Luqman So a couple of points:
  1. water should never be in your transmission fluid or oil
  2. Don't always beleive everything the dealer tells you.
On the first point, how do you know you have water is in your tranmsision? That's a sealed system and unless there's a crack an issue with the cover/bolt which holds the fluid in, there's no way water gets in there by itself. As for the engine oil, are you losing coolant? If not, how do you know you have water in there without removing the oil and checking it for contaminents?
As for the point about dealership trust. I've a good dealer relationship, however when I brought my car in recently for the Takata air bag recall, my MMI magically stopped working, they said I'd need to replace it for a $1500 figure and that was it. It took my 15 mins to determine that a 5amp fuse had blown and cost me exactly 10 cents to replace. So don't always believe what they say without evidence.
Get back to us on what they tell you, also who is your dealer and where are you located, since there may be someone local on here who can help you.
raj99 is offline
Old 04-23-2019, 10:43 PM
Nurke's Avatar
Just change your radiator and do a very good trans flush.
Nurke is offline
etreefiddy|$lave2bmw
Off-topic Discussion
01-03-2008 10:48 PM
amiro
09-13-2007 06:41 PM
1MZ-FE
03-18-2006 09:17 PM
Quick Reply: S6 2007 Car don't move doesn't change gear + water/oil mix in transmission & coolant
