swapped amp bose radio to premium bose radio
So, my amp went out. I got a new one and had cp removed. upon researching why many of my speakers would not work, and the sound was like **** and balance and fade were reversed, I figured out that the amp I got is the premium Bose amp, and my old one was regular. You can see in the pictures below that the wiring for these two amps is different, I am thinking about how to rewire for the premium amp to work correctly, but when looking at the wiring diagrams I see the regular system has an extra amp that the premium does not. so should I remove it? See the pictures below.
if you have this problem, rewiring the wiring harness is the only option i can see.
regular bose wiring diagram
premium bose sound system wiring diagram
Premium bose amp
Premium bose amp
Regular bose amp
Regular bose amp
Premium bose amp
Premium bose amp
Regular bose amp
Regular bose amp
What are the part numbers on the different amps? Also, can you show the plug side for both amps in the same image?
Part number of original amp:
4F5 035 223E
part number of replacement amp:
4F0 035 223G
the actual plugs are all the same albeit in slightly different location. The pinouts are slightly different as shown in the diagrams.
this is the extra preamp the old system has which the new one doesnt but I still have wired in Part no 4F0 035 223 B
4F5 035 223E
4F0 035 223G
Just rewire.. Cut away that little amp... Should work.
Seems like it's only for the right front bass speaker..
Maybe they forgot to have it in the big amp.. 😁
imports only
10-06-2008 03:49 AM
Chuck-S4
11-29-2004 10:28 AM
bugzy SoCalEuro.com
17
01-08-2004 06:34 AM
