Terrible Gas Mileage Audi S6
#11
#13
I read earlier that you said that your check engine light came on, have you scanned for codes yet?
As for the acceleration issues I believe that once you replace the spark plugs you will see you that the car will start behaving better I would bite your time until you’ve done the work
Thanks again I will let you know what happens. Any idea how much $$ im looking at to change spark plugs and fuel filter; also, should i change my coil packs too or are they not related?
Yea, I wont deny it, I love flooring this car! I hope im not messing up the transmission, someone told me i should accelerate gradually to not mess up my engine or transmission, but i told him that im pretty sure the V10 can handle it.
#14
I paid $127 incl shipping for 10 plugs - NGK PFR6WT. The fuel filter (Mann WK 720/4) was about $28 IIRC. Fuel filter is easy DIY, plugs require a little disassembly.
#15
Guys is there any way to upload a video in here? I wanted to show you a video of my startup issue that I was mentioning, it seems as if it will start on first gear, go up to about 2 RPM and when it shifts to second gear, the RPM just keeps increasing instead of going back down and comming back up (like all cars ive previously driven). Any ideas?
#17
https://youtu.be/1HYPu3zm3HQ
Here is the youtube link. Please watch the full video. Best representation is around 1:00.
Here you go:
Prerequisites:
- Ignition ON and Engine ON.
- No Fault Codes stored.
- Transmission Oil Temperature must be between 60 °C and 90 °C.
- If the procedure does not succeed in the first try, make sure the temperature is above 80 °C.
- All driving and braking has to be done in partial load, avoid full throttle/braking!
- Normally the adaptation needs to be carried out when:
- Transmission Control Module has been recoded
- Input Shaft has been replaced
- Hydraulic Unit has been replaced
- Transmission Control Module has been replaced
- Transmission has been replaced
[Select]
[02 - Transmission]
[Adaptation - 10]
Channel 00
[Read]
[Save]
[Done, Go Back]
[Measuring Blocks - 08]
Block 010 (in 1st Row)
Block 011 (in 2nd Row)
[Go!]
Check fields 2, specification is ADP OK.
- Move the selector lever in position D and drive with partial load 20 m / 70 ft forward, then brake to standstill.
- Hold the brake for 10 seconds.
- Move the selector lever in position R and drive with partial load 20 m / 70 ft reverse, then brake to standstill.
[Done, Go Back]
[Close Controller, Go Back - 06]
#18
My recommendation would be to perform an adaption on the transmission: 6-Speed Automatic Transmission (01J/Multitronic) - Ross-Tech Wiki\
Here you go:
[Select]
[02 - Transmission]
[Adaptation - 10]
Channel 00
[Read]
[Save]
[Done, Go Back]
[Go!]
[Done, Go Back]
Here you go:
Prerequisites:
[Select]
[02 - Transmission]
[Adaptation - 10]
Channel 00
[Read]
[Save]
[Done, Go Back]
[Go!]
[Done, Go Back]
#19
The transmission adaption essentially resets your transmission and allow it to map to your driving style. Since, this is a new to you car, I'd also recommend you change the transmission fluid and filter...use the SEARCH and you'll see plenty of threads on it.
#20
+1. Find a 1-2 mile road that has little or no traffic, and do this. I did it on my A8 with the same ZF trans and was very happy with the result. It lets the trans adapt itself to your driving style.
