Strange issue...
Strange issue...
i have noticed an issue with the revs when engine braking around 50mph, the revs seem to jump up and down but the car is not changing gears , and it stops around 30 mph
it doesn't happen al low or high speed
no faults on WAG COM
see video below
any ideas ?
see video below
any ideas ?
Torque convertor?
While researching issues with my A6 C6 Avant TCU (part of the valve body and collectively called a mechatronic unit), I came across someone who had similar issues and ended up being the torque convertor.
I'll see if I still have the link to the report.
Last edited by allroad Mason; 08-12-2015 at 12:13 PM. Reason: Additional info added
Without hijacking the thread, is there any proof of torque converter causing this or is is just anecdotal evidence? I remember reading a while back about someone replacing the torque converter and the issue still persisting. Also in another post, the throttle body was replaced and the issue resolved. ZF transmissions are used in a wide range of cars, does anyone know of any other cars other than Audi with ZF doing the same thing? If I was to take a stab in the dark, I would go with replacing the throttle body. Easier and cheaper.I highly doubt that TC is causing that rpm flare.
Another vote for the torque converter. I had the same symptom on my old 05. Throttle body did not correct it. Replacing the torque converter fixed the problem.
wtmmm
21
04-17-2021 05:46 PM
PaulW
11
07-24-2006 03:22 PM
Ler
10
01-21-2004 12:38 PM
