Tranny confused when stopping?
Just picked up an 06 A6 Avant. When coming to a stop sign, it feels like the trans is slow getting down to 1st gear. If I don't wait stopped for a second or two, I either get no initial response when first pressing the accelerator or it jumps down to 1st (rather hard I'd say) and then goes. I had this problem with my 03 but only after about 180K on the clock. Only 75K on this, but my first 6 spd automatic. Happens whether cold or hot. Tranny flush maybe?
At your mileage, it would be a good idea to do a tranny 'drain and refill' NOT a flush. Since ZF, the manufacturer of the actual transmission, recommends that this be done every 60k miles
Here's the BEST post I've seen on the job: https://www.audiworld.com/forums/sho....php?t=2816950 A couple of things to remember: 1 - use the correct fluid for you tranny (don't skimp on this - ZF) 2 - having a vag-com is required 3 - a lift is VERY VERY helpful 4 - remember to top-up as you turn on the engine and go through the gears If you don't want to do the job yourself, which I don't blame you, make sure whomever does it knows a thing or to about Audis/VW cars and has a vag. Good luck |
Originally Posted by raj99
(Post 24501844)
Here's the BEST post I've seen on the job: https://www.audiworld.com/forums/sho....php?t=2816950 A couple of things to remember: 1 - use the correct fluid for you tranny (don't skimp on this - ZF) 2 - having a vag-com is required 3 - a lift is VERY VERY helpful 4 - remember to top-up as you turn on the engine and go through the gears If you don't want to do the job yourself, which I don't blame you, make sure whomever does it knows a thing or to about Audis/VW cars and has a vag. Good luck Thanks AJG |
raj99, I'm guessing you're not in the Mercon SP crowd? Just wondering. I'm got a high mileage C6 A6 and considering the flush with Mercon based on everything I've read.
(OP, if you do some search you'll find that some people think Ford Mercon SP to be the same as ZF, only about 90% less expensive. However, it's impossible to know if they really ARE the same, although Blackstone says they're virtually identical and they're made in the same plant) |
Yes you are correct I decided to go with OE fluid for my tranny. I did look into Mercon, but the fluid my car had in it was ZF Lifegaurd 8 and the fact was that I got the fluid for about $23/liter and needed 5 liters of it...well it wasn't worth the risk.
From what I've read the Mercon seems to be compatible with the ZF6, but I didn't read anywhere which definitively stated that it was an alternative for the ZF8. Perhaps I'm mistaken. I look at things over the long haul and the fact is that you only change tranny fluid perhaps every 5 or so years. If saving the $100 or so bucks on the tranny fluid is worth it to you, that's your choice. I just decided that amortized over the course years, that getting the OE fluid was my preferential choice. BTW, I bought the fluid from here: http://www.thectsc.com/catalog/6_speed-58.html good luck
Originally Posted by Catamount90
(Post 24501859)
I agree with Raj. I have had the ATF changed 3 times so far and have always used OEM fluid.
while is sounds like tranny is not shifting smooth, I think the cause of your problem is different.
physically clean your throttle body and then using VAGCOM, do a throttl adaptive reset, link below for directions https://www.audiworld.com/forums/sho...php?p=24272830 |
Originally Posted by newa6er
(Post 24501988)
change the tranny fluid sooner vs. later...see if that remedies the issue.
(Post 24503314)
