Last edit by: IB Advertising
- Audi A6 C6 How to Replace Valve Cover Gasket<br>Step by step instructions for do-it-yourself repairs.
Valve cover DIY?
#11
Also, I think the gaskets themselves cost about $130.
#12
The labor time guide to replace both valve cover gaskets is 2.9 hrs for my 2008 A6, 3.2L. I used Victor Reinz gaskets from Napa which cost about $45 total for both and they have been leak free for over 3 years.
das60 (01-26-2023)
#13
T30 Torx
If anyone requires a T30 Pivot Torx (as pictured) I have some available. I used this tool for the rear valve cover bolts and the tool is definitely worth its weight in gold!! Please feel free to direct message me if interested.
das60 (08-05-2020)
#14
If anyone requires a T30 Pivot Torx (as pictured) Attachment 91834I have some available. I used this tool for the rear valve cover bolts and the tool is definitely worth its weight in gold!! Please feel free to direct message me if interested.
It's just a wobble extension which allows more flexibility.
Heck even HD sells it and you can buy these everywhere: https://www.homedepot.com/p/Bondhus-...8730/302015109
#15
Yeah, not that special to require a PM since I referenced it in the thread earlier: https://www.audiworld.com/forums/a6-.../#post24429968
On my S4, a socket+wobble+extension definitely did not fit!?
Also, HD doesn’t have this tool in Canada.
#16
If you are looking to sell your product, go post in classified, but don't spam for something that can be had at any decent h/w shop. As for being in Canada, I'm pretty sure Canadian Tire or Rona caries some form of these.
#18
The guy who made this
about replacing the cam timing chain tensioners was emphatic that the valve covers would leak if the bolts were not replaced in addition to the gasket. A complete set costs $27-33 on Amazon, but there is no mention about a need to replace them in this thread nor have I heard it from anyone else. Does anyone reading this have enough experience or knowledge to say with confidence whether replacing the valve cover bolts is required or at least highly recommended? I do know the bolts contain a rubber grommet so it's at least plausible that replacement would be wise. TIA for all replies!
#19
I didn’t use any special tools to do them, I’ve done them on both my A6s, 3.2 and the 3.0T... as for the time, 7 hrs?! Holy crap, couple hours at most, that’s including 420 breaks and vodka drinks.
remove air box and tube, coil packs then take it off... how can anyone charge 7 hrs for that? Horrible.
#20
The guy who made this Youtube video about replacing the cam timing chain tensioners was emphatic that the valve covers would leak if the bolts were not replaced in addition to the gasket. A complete set costs $27-33 on Amazon, but there is no mention about a need to replace them in this thread nor have I heard it from anyone else. Does anyone reading this have enough experience or knowledge to say with confidence whether replacing the valve cover bolts is required or at least highly recommended? I do know the bolts contain a rubber grommet so it's at least plausible that replacement would be wise. TIA for all replies!
das60 (01-26-2023)
