VCDS Fault Diagnostic Scan
Hi guys
could you help with decipher the faults below ? I had a full scan done today and these 2 that came up .
2 Faults Found:
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 162573 km
Time Indication: 0
Date: 2006.03.19
Time: 07:17:59
Freeze Frame:
RPM: 882 /min
Torque: 140.4 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.98 V
Duty Cycle: 24.1 %
Temperature: 17.1°C
004195 - Fuel Pressure Regulation
P1063 - 004 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170723 km
Time Indication: 0
Date: 2015.06.03
Time: 13:16:01
Freeze Frame:
RPM: 819 /min
Torque: 89.7 Nm
(no units): 15.0
Voltage: 14.06 V
Pressure: 106.5 bar
Duty Cycle: 33.9 %
If you live in London i can recommend Tony who was very good and helpfull ( went to see him this morning and for £10 he activated few things in MMI and scanned for faults )
GREATER LONDON VCDS Fault Diagnostic Scan - FULL VAG COM Scan / Coding | eBay
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 162573 km
Time Indication: 0
Date: 2006.03.19
Time: 07:17:59
Freeze Frame:
RPM: 882 /min
Torque: 140.4 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.98 V
Duty Cycle: 24.1 %
Temperature: 17.1°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170723 km
Time Indication: 0
Date: 2015.06.03
Time: 13:16:01
Freeze Frame:
RPM: 819 /min
Torque: 89.7 Nm
(no units): 15.0
Voltage: 14.06 V
Pressure: 106.5 bar
Duty Cycle: 33.9 %
Both codes were only triggered once so 99% it's just a fluke and no worry at all. Just clear them drive for awhile and see if they come back. In which case:
Triggered 19 March 2006
Bad glow plug. If this code ever come back repeatedly and you decide to swap the glowplug yourself then take heed on post #10 in this thread.
Triggered 03 June 2015
This could be either leaking injectors or failing fuel pump. Take off the plastic engine cover and look if there is gas leak around the injectors. The seals do harden up and may crack. In which case it's a simple procedure. However since this code was only triggered once I would not worry. Just clear and scan the car in a week or so to see if it comes back.
Injector O ring replacement:
Take fuel pump fuse out. Start the car let it die.
Disconnect fuel rail from the block
Pull injectors out and replace O rings
Put injectors back
Secure fuel rail
Put back fuel pump fuse
Done
Put injectors back
Secure fuel rail
Done
It did not come back and it's the original code. FYI some codes you can't clear by the "Clear all fault codes" in the auto-scan section. You have to actually go to the particular module and clear it from there.
update
so i have checked the faults again and only 1 came back
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 402 D HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0020
Revision: --H03--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
VCID: 1E3338FAC917D8EE86F-804B
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171961 km
Time Indication: 0
Date: 2015.06.25
Time: 06:47:10
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.70 V
Duty Cycle: 15.0 %
Temperature: 19.8°C
Readiness: 0 0 0 0 0
any ideas ?
Coding: 0011372
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171961 km
Time Indication: 0
Date: 2015.06.25
Time: 06:47:10
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.70 V
Duty Cycle: 15.0 %
Temperature: 19.8°C
any ideas ?
update
Coding: 0011372
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171961 km
Time Indication: 0
Date: 2015.06.25
Time: 06:47:10
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.70 V
Duty Cycle: 15.0 %
Temperature: 19.8°C
any ideas ?
Coding: 0011372
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171961 km
Time Indication: 0
Date: 2015.06.25
Time: 06:47:10
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.70 V
Duty Cycle: 15.0 %
Temperature: 19.8°C
any ideas ?
08 S5
02-16-2008 10:41 AM
jensenkd
VAG-COM Discussion
06-29-2006 07:06 AM
RKJ
01-02-2003 06:59 PM
Merou
02-05-2002 04:30 PM
