VCDS Modules cannot be reached, many errors
Hi everyone
I have some problem.
While I checked fuse, because window washer stop working (during checking fuse ignition position was: ON, engine was: OFF, MMI 2G HIgh was: ON - radio was playing), when one 5A fuse was removed, it appeared sound like low level fuel, and yellow battery symbol. MMI stopped working, also control panel of MMI. Next I disconnected battery, and connected cable + and - together for few seconds and time and date have been reset. Finally i checked fuses (front side driver, passenger and trunk side by battery).
Before that i had only two errors in log (VCDS):
1: Left Parking Brake Motor (V282) Clamping Force Not Reached (it needs replace)
2: Supply Voltage Term 50 (I don't know reason)
But now there are a lot of errors.
Please check attached file, there is full logs.
Now many modules cannot be reached, like MMI, Radio and there are errors.
I think that checking fuses with ignition position "ON" was bad idea.
wonder1and
9
08-27-2005 02:08 PM
TheObiJuan
03-13-2004 07:47 PM
