Where the engine oil goes?
Where the engine oil goes? update new symptom?
Yesterday 6/29th before I went to work I check the oil on cold engine which was resting overnight and for my surprise the oil was over max on the dipstick. Than I start the engine and the oil was gone, dry dipstick again and also I check from the top with flashlight but I cant see no reflection on the belly pan.
HI all.
I have a "little" problem and i`m a "little" concern. i do have 2006 Audi a6 4.2 for 6 years nothing major till now (i think). Im another DIY so when it comes to routine maintenance im not afraid to get my hands dirty. So let me jump straight to the problem.
Last Oil change was performed on Jan 27 2013 also was 74300 and it was considered 75K. Oem oil Filter and Mobil one extended performance 5w-30.
FF to present day actually yesterday my family and i went to Poconos to visit friends about 100 miles one way? so about 15 mil to the destination engine oil light came ON. found local walmart and bought the same oil, topped around 1 qt and it was all good.
Today Memorial day so we were hitting on BBQ in the in-laws house. I said to my self let me check the oil. pUll the dip stick out and it was dry no oil.the car is running but still the stick is dry and no light (oil min). topped another 2 qt went to middle of the stick and is good again. I made round trip today roughly 40 miles.got home i check the oil and its gone. it shows 1/4 of the orange bottom plastic on the dip stick.
And now what.
right now i have 76400 mi and No smell,no smoke no drip of oil and the antifreeze is on level.
what else is there to be check?
Any ideas pls Shoot
Thanks
HI all.
And now what.
Any ideas pls Shoot
Thanks
First thing I'd do is remove the belly cover and see if you find oil that way. Cars with belly cover's are notorious for hiding leaks.
Otherwise, thats extremely high oil consumption and I'd take it in to get taken a look at.
HI all.
And now what.
Any ideas pls Shoot
Thanks
And now what.
Any ideas pls Shoot
Thanks
It's amazing how much oily muck those belly pans will hide!
Does the oil you are using meet the engine mfr's minimum viscosity spec?
Can you check the engine oil level when the engine is running?
Update new symptom?
Yesterday 6/29th before I went to work I check the oil on cold engine which was resting overnight and for my surprise the oil was over max on the dipstick. Than I start the engine and the oil was gone, dry dipstick again and also I check from the top with flashlight but I cant see no reflection on the belly pan.*
I suggest you take the time and remove the belly pan to be 100% certain you are not in fact leaking. Furthermore, having too much oil in your system is also a bad thing, so you need to determine this for certain.
