2014 Audi A7 weird ACC issues
Hi,
We are working on a 2014 Audi A7 with a very weird problem. This car is equipped with adaptive cruise control. Whenever the car started, we are getting an error message stating that "acc and audi braking guard not available" but a second after it, the message disappears completely (No exclamation mark on the cluster) and everything goes back to work properly, including the adaptive cruise.
We have scanned the car both with rosstech and ODIS online, I have attached the VCDS scan below. Both ACC modules are throwing many error messages, and it seems like some of the messages core codes, are referring to no communication to the airbag modules (FAULT_CIM_TIMEOUT_Airbag_01) etc.
Has anyone ever experienced anything like it?
We do not have access to Elsa Pro (Just to ODIS online). Is there an SVM code for update to the ACC modules, or to any other modules that can be related to it?
We have tried to do online SVM comparison but there was nothing to change.
Thanks!!!
Friday,17,August,2018,16:35:52:41975
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4427.4
Data version: 20180518 DS287.1
http://www.Ross-Tech.com
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3B 3C 42 44 46 47 52
53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90
VIN: WAUWGAFC7ENxxxxxx Mileage: 36551km-22711miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CTUA) Labels: None
Part No SW: 4G0 907 551 J HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0004
Revision: --H07---
Coding: 1A2A0032056601060000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551J 001004
ROD: EV_ECM30TFS0214G0907551J.rod
VCID: B02C6BD1EB8024C417-80E4
No fault code found.
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1006
Revision: --H16---
Coding: 000002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: AD1272A5FCB2492C3C-80F8
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Revision: -------- Serial number: --------------
Coding: 44A7970322E5E9C05B00
ASAM Dataset: EV_ESPPremiAU57X 004039
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: BB364CFD32C6D79CB2-80EE
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 ER HW: 4H0 907 064 ER
Component: BCM2 2.0 H36 0521
Revision: 00002001
Coding: 0DAA2046000000000000
VCID: FDB282E5645219ACCC-80A8
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 0214000018549006
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 4G0 820 043 AQ HW: 4G0 820 043 AQ
Component: KLIMA 2 ZONEN H14 0094
Serial number: 24021400111162
Coding: 668320184D
ASAM Dataset: EV_AirCondiBasisUDS 004002
ROD: EV_AirCondiBasisUDS_004.rod
VCID: EE90B5A93134723445-80BA
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001846466
Coding: 06002091063C9FE28100088380003928CF9CD208A609022100 0004406000
VCID: EFAEA8AD3E3E7B3C4E-80BA
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 140217 H37 0080
Serial number: 140219153029
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22300243
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 12 02 2014 00000328
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R2K1J02
Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 07B88417000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061405601389
Coding: A8EB03
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: F1AAAED5200A6DCC58-80A4
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Serial number: 00000000000000
Coding: 7E01010201
Shop #: WSC 00736 003 1048576
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: A81C83B1D3506C04CF-80FC
10 Faults Found:
21760 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_APSM]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:59
Control Module temperature: 72 °C
Voltage terminal 15: 12.459 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: -0.01 m/s²
22016 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_01]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
Voltage terminal 15: 12.029 V
22272 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_02]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
22528 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_03]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
22784 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_04]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
23040 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_05]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
23296 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_06]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
23552 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_07]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
23808 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_08]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
24064 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_Master]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8003WVZ$
Coding: 303145313131303031304A55304C34473853
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: B32664DD1A961FDC6A-80E6
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y1400012CYT07
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40572BDG0115B
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB405T2B8KKB9K0
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB401C50STULP6H
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB401A50TT6NH5T
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400M50SAEH26M
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400M50SAEM9PB
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372MJA000IB
Coding: 0004FC
VCID: B83C53F10BF0FC845F-80EC
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H08 0010
Serial number: 20 09 2013 D0315133
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 984 R HW: 4G8 920 984 R
Component: TBenUsaAcc H58 0621
Revision: 29460235 Serial number: 658200214596031
Coding: 0BC601060F53D705020100
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: C5C22A054402916CD4-8090
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001284358
Coding: 00CD073000
ASAM Dataset: EV_GatewPkoUDS 001019
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: F2A8A1D9250C56D4A1-80A6
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 2022612603
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 1312140000000000016A
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000090994484
Coding: 00581B0000006001000001010101102030303232203232
VCID: F7BE90CD466E33FC96-80A2
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H03 0056
Revision: -------- Serial number: EJ1BPA8206CVGQ
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: B6205DC909E40AF44D-80E2
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH04 0060
Revision: 00H04000 Serial number: 6PZ 010 287-08
Coding: 0000003
VCID: B6205DC9C1E40AF44D-80E2
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H04 0060
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F17.02.1400H04000AMS15233ÿ
Subsystem 4 - Serial number: S15233ÿ
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F57025E00628002000413
VCID: C5C22A054C02916CD4-8090
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H39 0010
Revision: 00001000 Serial number: 0028095518
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: B22861D9E58C16D461-80E6
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0327928388
Coding: 0126023A20FAF08580B00A0402030D47000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000206201
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO27346714
Coding: 101F00
Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA107531000006101122
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93164907
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000074248
Coding: 010000
VCID: 9D72A2658412B9ACAC-80C8
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0507
Coding: 011F57025E00628002000402
VCID: C6C02D0971049A74DD-8092
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H03 0015
Revision: -------- Serial number: 00000000968348
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 140219-0002-122
Coding: 1223A6101002A500
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
Address 56: Radio ® Labels: Redir Fail!
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156B%0E7971860
Coding: 020007010000000001
VCID: A4049781A7788864E3-80F0
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 F HW: 4G0 035 746 E
Component: H-BNT-NA H41 0757
Revision: -------- Serial number: 194B20E7602987
Coding: 090200040003E8EF7D12CB1E00000003100001000000000000
VCID: AA1879B9C55C5E14D9-80FE
Subsystem 1 - Part No: 8R0 060 884 BL
Component: NAR 2014 0902
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD003VD9+
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349NBR00025
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5571
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0507
Coding: 010F17024000628002000002
VCID: C9DA2635601A750C30-809C
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 B HW: 7P6 907 441 D
Component: TopView H05 0220
Revision: 11001001 Serial number: 82330JF0133210
Coding: 0205000001010100000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
ROD: EV_CamerSysteTopViewAUDI_007.rod
VCID: AC147FA1C7A840242B-80F8
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 R HW: 4G8 959 107 G
Component: HDSG-Modul H13 0043
Revision: 12013001 Serial number: 038400135
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: C4C437014F38A864C3-8090
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0507
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: -------- Serial number: 262130025421000
Coding: 6A060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: A6008D89D9447A74FD-80F2
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7E01010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
10 Faults Found:
32512 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_LWI]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
Control Module temperature: 62 °C
Voltage terminal 15: 12.178 V
Velocity_vehicle_reference: -0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
34816 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_SWA_01]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
Voltage terminal 15: 12.210 V
35072 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_SWA_OBJLI]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
35328 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_SWA_OBJMI]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
35584 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_SWA_OBJRE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
38144 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Airbag_01]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:33
Voltage terminal 15: 12.566 V
38912 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_APS1]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
Voltage terminal 15: 12.302 V
38656 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_APS2]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
27136 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_BVS_STATUS]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000122602147
Coding: 03C198180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: B12A6ED5E08A2DCC18-80E4
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:41, VBatt start/end: 13.8V/13.5V)-----------
Thanks!!!
Revision: --H07---
Revision: --H16---
Coding: 000002
Revision: 00002001
Coding: 668320184D
Coding: 0045F7
Coding: 02006E
Coding: A8EB03
Coding: 7E01010201
10 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:59
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:57:58
Coding: 0004FC
ROD: EV_RBD4K.rod
Coding: 00CD073000
Voltage stabilizer:
ROD: EV_SARA2.rod
Coding: 0000003
Coding: 101F00
Coding: 010000
Coding: 0A3305C102
Coding: 6A060000
Coding: 7E01010201
10 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:33
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 214
Mileage: 36551 km
Date: 2018.08.17
Time: 15:54:32
ROD: EV_BC7.rod
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
JeepRage II
06-27-2003 07:25 AM
