25% Discounts! - Revo by Alcon 355 and 380mm Big Brake Packages...
Audiworld Basic Sponsor
Revo by Alcon 380x32mm Big Brake Package $2665.00 set (Retail - $3595.00)
Revo by Alcon 355x32mm Big Brake Package $2665.00 set (Retail - $3595.00)
Information:
- New Floating Systems Newly developed floating system allows greater heat handling capacity and quieter running.
- No More Fade Higher heat absorption and dispersion for shorter stops, turn after turn.
- No Warping Specially designed two-piece floating rotors for quiet, warp-free performance.
- Quicker Reaction Time Short consistent pedal travel can save your life in a panic situation.
- Improved Pedal Feel Firm confidence-inspiring brake pedal due to ultra-stiff calipers, differential piston sizing and stainless steel braided lines.
- Less Weight Enables shorter stops, quicker acceleration, improved steering feel and handling.
- Lower Long-Term Maintenance Costs Cutting-edge design in a durable, low-cost system.
- Compatibility and Ease of Installation Compatible with ABS and traction control systems with brake bias designed to ensure ultimate gripping power; all hardware is included to ensure a quick and seamless installation.
Revo by Alcon calipers are cast from one piece of aluminum. This single casting design with the cross bridges cast in place creates a very stiff unit and very little compliance during braking. Less compliance means less pedal travel because the brake fluid is only applying force to the pistons, not bending the caliper. This applies the maximum amount of force to the Ferodo performance brake pads. Our brakes use ultra-high-resilience piston seals, with proprietary retraction angle shape, minimising piston travel distance for less dead pedal travel and resulting in better pedal feel in the vehicle.
Brake Rotors:
Racers have long used floating disc technology, but the discs found on racecars move freely on the floating pin drive connecting the bell to the disc, causing noise. To eliminate the rattling race disc for our street car customers, we have re-engineered the floating system using noise-reducing methodology that eliminates noise but still allows for thermal expansion with expanding floating capabilities to handle higher temperatures.
- Crescent grooves in the surface of our Alcon brake disc perform three basic functions: Increases initial friction between the disc and pads, producing more bite, continuously refreshes the brake pad surface by removing debris from the pad and prevents build up of gas from the phenolics within the pads.
- Our brakes rotors 252 vanes to draw air from the center of the disc outward. These vanes work like a pump to move cool air through the center of the disc, taking the heat away from the disc and cooling it before the next heavy braking zone.
Ferodo DS2500 Brake Pads offer low and high speed braking efficiency, reduced stopping distances and a consistent brake pedal feel from the start. This new generation of friction material is very low in compressibility ensuring a firm pedal, whilst still providing low wear rates for discs and pads. Combined with low wheel dusting and good noise characteristics, this compound is the brake pad for the driver who demands the ultimate in track day braking performance.
Brake Lines:
Hosetechnik Stainless Brakeline Kits are manufactured with the finest quality hose, consisting of a PTFE inner and stainless steel braided outer to improve braking performance, eliminate the spongy feel of the original rubber hoses, and provide superior resistance to abrasion and corrosion. These kits not only provide the reliability and safety demanded in a brake system, but offer good looks that improve the appearance of any installation.
Brake Fluid:
Motul Dot 5.1 brake fluid is a long life 100% synthetic brake fluid suitable for all types of hydraulic actuated-brake and clutch systems that require DOT 5.1, DOT 4 and DOT 3 manufacturers brake fluid recommendations.
Particularly suitable for use with anti-lock braking systems (ABS).
- Long life brake fluid
- 100% synthetic brake fluid from polyglycol bases.
- Dry boiling point 270 °C / 518 °F
- Wet boiling point 185 °C / 365 °
Wheel templates are available upon request. Please email to receive these if required: contact@europrice.us
Delivery:
Some kits are ready to ship for your order depending on caliper color and rotor sizing. Delivery estimates can be obtained via PM or email: contact@europrice.us Shipping is via major carrier to all locations, any duty/brokerage fees are the responsibility of the recipient if located outside of the US.
Questions, Quotes:
If you would like a quote including delivery please add the product to your cart and view the cart to estimate. If you have any questions or needs other than those posted above please don't hesitate to PM or email: contact@europrice.us
Thanks!
Alex@Europrice.us
S7
05-23-2018 09:05 AM
Alex@Europrice.us
S6 (C7 Platform) Discussion
05-23-2018 09:04 AM
Alex@Europrice.us
A6 (C7 Platform) Discussion
05-23-2018 09:03 AM
Alex@Europrice.us
S4 (B8 Platform) Discussion
05-23-2018 09:02 AM
Alex@Europrice.us
A4 (B8 Platform) Discussion
05-23-2018 09:01 AM
