6396 - Linear Oxygen (Lambda) Sensor B1 S1 Pump Current Trim Circuit
I encountered a check engine light the other day on my 2012 A7, and after scanning with VCDS, here is the output:
Is there a way to disconnect that sensor connector from the top? I can barely reach it with my hand, but I was unsuccessful disconnecting that harness.
Any advise is highly appreciated.
P2626 00 [175] - Open
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 7
Mileage: 138754 km
Date: 2018.10.29
Time: 17:20:38
Engine speed: 1323.00 /min
Normed load value: 0.0 %
Vehicle speed: 58 km/h
Coolant temperature: 96 °C
Intake air temperature: 57 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.812 V
Unlearning counter according OBD: 40
Engine speed: actual: 1216 /min
MAF_ENVD: 76.25882 mg/stroke
Coolant temperature (unfiltered): 96.00 °C
Engine: operating status: PUC
T_AST_ENVD: 179.90 s
STATE_LS_ENVD[1]: 4
Readiness: 0000 0000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Mileage: 138754 km
Date: 2018.10.29
Time: 17:20:38
STATE_LS_ENVD[1]: 4
I had it done after looking at is by purchasing a borescope and viewing how is attached. All i had to do is, use a small screwdriver to slide out from the retaining metal plate support where both connectors S1B2 & S1B1 are. Also, please be aware, that while the S1B1 was out, and driving the car for less than a week the passenger cat ageing showed higher than usual numbers in VCDS, like in 0.25xxx from 0.15xxx. If left alone, that would likely clog the side of catalyst converter quickly.
beejohn
10-26-2008 03:05 PM
SpencerB
Audi Original "S" Cars
10
07-02-2007 04:21 PM
