Audi A7 front grill care
Hi, do you have any ideas or suggestions how to care/repair about A7 front chrome grill? Mine has some scratches and I don't know it's a bra or paint?!! They say if i buy a new I will have the same trouble in several months, what have you done with yours? Should i paint the black part or use bra? Thanks
Audi Enthusiast
Mine was peeling badly after 118,000 miles of road duty. I ended up taking it off and repainting it. I removed the chrome trim before getting to work on it. The hardest part was getting the remaining paint off. I tried using a chemical to remove the paint, but that didn't do anything, so I ended up using a razor blade to remove the rest. I then used a super fine sandpaper to prep the surface, followed by Rustoleum Gloss Black paint. I think it turned out pretty good, if not quite as glossy as the original paint. In the future, I may redo it with touch-up paint to match the original, but it sure looks better than it did. We'll see how long it holds up.
Wonder if wrapping in full gloss metalick 3M would be easier and probably more resistant?
Audi Enthusiast
If I remember correctly... I used a pry tool to help pry apart the tabs on the back that hold onto the chrome tab, and then gently push it through. It's a bit tough and have to be careful not to break the chrome, of course. Start on the ends and work your way towards the middle.
How much did you guys spend to repaint the grill? I have a 2016 Audi A7 and a road debris flew into my grill and damaged it at the lower margin of it and didn't touch the plate delete panel so I ordered a new grill online from a Audi dealership in New York for only 360 dollars and shipped it to Michigan so its not bad compared to the 520 dollars MSRP price from Audi. I wonder if thats a far better way of spending the money then repainting a grill.
Audi Enthusiast
