Audi A7 MMI Screen is blank
#12
It's most likely the 5F (MMI) controller that will need to be replaced. If you purchase the part new or used, the dealer will still need to re-code to the car. This can only be accomplished when the dealer is connected to the VAG database as prevention for stolen car parts making it back onto production cars.
Enjoy the ride!
Enjoy the ride!
#14
MMI blank screen is fixed
Hello all, today I was successful on fixing the screen. Thanks to my friends at HiTech electronics that gave me the pointers as to what the problem was. It turns out there is a connector with two wires connected to the screen that carry the power to the screen. These wires break not far from the connector, somewhere between five and seven inches from the connector. In some cases the wires, once broken, can short and blow a fuse. I removed my screen again and found the wires completely broken, both of them. I repaired it using some solder and some silicone wires and replace the fuse and now I have a bright shiny working screen. It felt so good to be able to turn off the yellow lamp for the tire pressure LOL. Anyways, there is an album in my profile with some pictures I took of the broken wires and the connector that is needed. No special tools needed to remove the screen, it is fairly simple. Good luck to those that are suffering from this bad issue. I hope this helps someone else and a shout out to the folks at HiTech Electronics, their help was invaluable.
The cavernous nest of the MMI screen
Stupid power wires break about seven inches from the connector.
Similar view of the broken wires.
More detail
Turn on the radio and voila, after fixing the broken wires.
More detail
The following 4 users liked this post by fstkmaro:
AesQlapius (10-24-2022),
Corey Word (03-09-2021),
motocrossgrl99 (02-04-2023),
Salman electrician (05-01-2020)
#15
More detail
More detail
Thanks fstkmaro for posting this info!
#16
Thank you. Special thanks to the folks at HiTech electronics. It was frustrating for me to drive around with the broken screen and having invested in a replacement for it to be two silly wires LOL. I am happy it was that simple and happy to see this is helping some folks. I hope they pin this post as I suspect many first gen A7s are suffering from this or will soon.
cheers
cheers
The following 2 users liked this post by fstkmaro:
Dannielle Smallwood (05-09-2020)
#17
cheers
cheers
#18
My screen has also gone black. Where did you look to replace the fuse for the screen? I'm not as car "savvy", but I did see a replacement screen on eBay for $200.00. I figured it would be a whole lot cheaper vs taking it to the dealer
#20
