Noises starting to drive me crazy...
First of all, clicking sound from the B-pillar every time I drive
- popping sound from the shifter trim where the leg touches - every time. - occasional rattling from the instrument cluster - occasional noises from the area around the MMI screen When the weather is nice I am going to start removing some trims and see what's going on. I am not going to have the dealer mess with it, as they are more likely to make things worse... Maybe the Stasis exhaust is loosening things in the car? |
Those kind of noises drives me crazy as well! Good luck to you, hope it works out.
I've got the same annoying noises from the lower plastic "pockets" on the front doors. They squeak on uneven road surfaces. I had the same issues on my last S5, I really don't understand why Audi can't make them fit tighter or at least divide the pocket so it's not one long plastic cover. :mad: |
My noises became more prevalent yesterday and I've got only 5k miles on it. I guess I'll attempt the dealership as I don't feel comfortable taking it apart. It does seem like its coming from the Pillar.
Also have b pillar noises that have gotten worse above the 5k mark...let's figure out what is happening here because the dealers are inept at fixing this stuff!
Originally Posted by rs4fun2008
(Post 24271465)
Yeah I hear ya. |
(Post 24271465)
Originally Posted by The G Man
(Post 24271757)
I have a C7 A6, the interior is very similar. I have the same B pillar noise, what I did was cut a strip of black velcro and squeeze it in betwen where the gray head liner material meets the black plastic, right below the seat belt adjustment area, I have the black interior and gray head liner. I took a piece of copier paper and fold it into 4 and squezze it into their first and drove around for a while just to see if that was the cause of the rattle before I put in the Velcro. Hope that helps.
Did you mean right "above" the seat belt adjustment area? |
Originally Posted by aquarian
(Post 24271927)
(Post 24271948)
No, below it, where the two different material panels meets.
1 Attachment(s)
Originally Posted by ratheito
(Post 24271954)
I think I have the same issue, if I understand you correctly. Could you please take a picture showing the area, and also the solution. Thanks!
