A7 window issue.
A7 window issue.
The driver's side window on my 2012 A7, 31,000 miles, has just started acting up. Using the one-touch up button, it rises to the top of the track, and then bouces back, returning to the 1/3 up position. I am able to move it up manually in small increments to within 1/2 inch of the closed position, but if I try to fully close it, it'll bounce back from there too. I have cleaned the track and window. I'm guessing it's a sensor problem, the "pinch-protect" feature possibly? Anybody else have issues with this? Ideas?
I had this same issue on my old Jetta a couple years back. Ended up being the regulator that was replaced and it was fixed, but I had my suspicions as to electrical.
Sorry I don't have the specifics, but maybe someone else can assist with those.
Best of luck.
Before going to the dealer, try this window reset procedure:
Start with the window fully closed.
Press the switch until the window is fully open and continue pressing it for 5 seconds.
Then pull the switch up until the window is fully closed and continue to hold the switch for 5 seconds.
Gator Smiles
04-30-2002 07:09 AM
digitalskate
03-28-2002 06:40 PM
