"CD00 ERR"
Delta CC head unit displays this when I put it in Cd mode. Checked every connection in the back of the deck that has to do with CD (green section if I remember correctly) and there is no loose wires. Pulled out the actual CD changer and inspected all connections, again no loose wire.
Any thoughts? Thanks |
Try different CDs, ones you know are in good condition
and if it still is giving you the ERR signal...then it's prolly time for a new changer. They don't last forever.
Re: Try different CDs, ones you know are in good condition
yeah the actual cartridge does not eject.
Re: "CD00 ERR"
Problem solved:
I removed the cd changer entirely from the bracket and unplugged it. Then I removed the outer casing to get a better view of the inside. I then took a ruler and felt around the actual magazine for a minute and eject it manually. I removed all the CDs, put the changer back together, and tested it. Everything worked. So I loaded a CD, still not full bolted back into place; it worked. I screwed/bolted all the casings and brackets and replaced the changer while keeping the magazine out. Tested again, all was well. So I loaded up CDs and replace the magazine. Also Note: If your CD changer seems to be jammed, lubricate the gears with silicon during this procedure. All the best -Daniel |
