1995 Audi A8 HID/Xenon headlight
Hello.
It's my first post in this forum.
I have a 1995 Audi A8 with HID/Xenox headlights. It is not a Bi-Xenon. It's a regutar single Xenon.
Last week, the left side bulb started to flash several times before getting steady solid light.
Questions:
a) Do anyone know what is the problem?
b) I need instructions to fix it (assembly/disassembly photos, if possible)
c) Do anyone know what kind if bulb is used in this car? The manual just say to look for an Audi dealer to get it fixed. It does not say what kind of bulb is used there.
Thanks a lot!
Angelo Marzolla
Sao Paulo - Brazil
Questions:
Thanks a lot!
Angelo Marzolla
Sao Paulo - Brazil
You can swap the bulbs left to right. If it flickers on the other side then just need a pair of bulb. If the problem stays on the same side then swap the igniters,----then the ballast. You will find the faulty part. '95 is still the D1 right?
TozoM8 is correct, but also Do not touch the bulbs with your bare fingers. The oil on your skin will get on the bulb and create a hot spot that will burn out the bulb for sure. If you do touch it then clean with rubbing alcohol and a tissue.
Bob
Bob
I am guessing they haven't been changed for a long time so I would replace both bulbs
lexakozakov
10-22-2015 01:58 PM
Theun
15
03-18-2006 03:18 PM
