Sponsored by:
Sponsored by:
1997 A8 Quattro leaking oil
Old 03-11-2009, 11:05 AM
  #11
mkurak's Avatar
Default Holy Semantics Batman!
They call one of those things that you put beer into a "cooler" and it doesn't cool anything (unless it's one of those fancy plug-in ones).
Old 03-11-2009, 11:11 AM
  #12
skiracer's Avatar
Angus started it ;-) LoL!!!
Old 03-11-2009, 12:01 PM
  #13
pkrasusky's Avatar
I'M COOLER
Old 03-11-2009, 12:42 PM
  #14
Member
jazbo123's Avatar
Yup, so are your lungs.
Old 03-11-2009, 12:56 PM
  #15
Member
jazbo123's Avatar
And I'll stop right there... since we're not OT Forum perverts 8-D
Old 03-11-2009, 01:05 PM
  #16
USMC Audi 8's Avatar
Default I figured out the leak on that problem...
There is a seal that is behind that plate where the rollers are. I replaced mine and whammo fixed it.
Old 03-11-2009, 03:26 PM
  #17
New Member
SWiseman's Avatar
Default Can you give more details. I have the same oil leak also. Hoping to fix it soon.
More information is appreciated.
Thanks
Old 03-12-2009, 07:21 AM
  #18
Junior Member
CalG's Avatar
Yah... Mine is leaking there :-(
Old 03-15-2009, 02:37 PM
  #19
RJPUK's Avatar
Default Re: Can you give more details. I have the same oil leak also. Hoping to fix it soon.
My UK 98 32V S8 had a large oil leak onto the alternator bracket, apparently from the region of the cambelt idler pulley carrier plate. It turned out the external bearing of the oil pump shaft had broken up. This is the *lowest* pulley on the cambelt, but the oil was tracked up by the belt/ spun up by the pulley, and dripped back down. Replacing this (and the shaft seal behind it) cured the problem. The 40V motor avoids this by having an internally driven oil pump. There seems to be no gasket, or source of oil, higher up, except for the camshaft seal (which was replaced as a preacaution).
4rings.s8
09-05-2017 04:21 PM
mitchell8139
08-10-2016 08:59 AM
AK_92_V8
06-13-2009 03:32 AM
OWDI_A4
02-27-2005 06:01 AM
AudiNutA8A6
10-03-2003 07:28 PM
Quick Reply: 1997 A8 Quattro leaking oil
