1998 Audi A8 (D2) unplugged trans connector / Safe mode
#12
Now why wouldn't the TCU put the car in limp mode? Seems like limp mode would be preferable to leaving somebody stranded on the side of the road with this failure.
Is there a list of conditions that need to be satisfied to put the trans in limp mode available somewhere?
#13
That is a long list.
Incorrect gear ratios
tc faults any wiring wiring related to trans
any solenoid/pressure regulator valve faults
input/output speed sensor faults
temp sensor fault
F125 switch fault
any OBD code from P0700 to P0800
temp sensor fault
F125 switch fault
We've learned a lot from tozoM8 over the years.
#14
Those make sense. But if the problem description is correct, I'm not understanding something. How come the car can't move forward at all with the TCU hooked up, but it will drive like it's got a blown A clutch when the TCU is unplugged? Shouldn't it be able to drive in 5 and reverse regardless of the wire bundle being hooked up or not? The symptoms as described would seem to imply that if all forward movement is disabled, we could cut (or unplug) the wire bundle and then (maybe) drive it home in limp mode. Screwy, no?
#15
Morning ... I agree with you. Rather odd the A8 drives well without being connected to TCM or TCU. After my search under the car I did not see any frayed, pinched or damaged wires to the TCM. Now it’s at trans repair shop and after connecting it the car is showing more codes. It’s seems there’s a programming situation according to them, I’m awaiting an update. I have shared each of your input w the shop to guide this endeavor quickly as I’d like to drive this A8. Sorry for the late update I will share once I am informed and thank you again for the directions and suggestions ... Weave
#17
I appreciate all of your suggestions and input. I have since reclaimed the A8 from the transmission shop. They state that their transmission guru advised them to not R&R my car. They said they could not offer a warranty for their work so I was not charged for the 2 week review. The A8 now starts without the red block of "PRND432" and drives for a few miles before I hear a loud clunk. At this point the red block returns and my A8 drives back in safe mode. Once i turn off the car and re start, itll appear and goes through the same pattern. At this moment I cannot find a used matching trans nor do i have the extra $$ to R&R my OE trans to be revived. The trans shop also declined the repair since they couldnt find the parts available and they claim they consulted several ZF vendors for parts that dont exist.
Rather interesting endeavor but I will ship my trans soon to European Trans in GA to revive and refresh with new parts for $2,200. They warranty their work w new valve body, torque converter and etc
I am seeking a place in San Diego to perform this removal, If you can refer me to a shop that can assist me in the R&R I would appreciate it
Weave
Weave
#18
Weave
Weave
#19
Morning Dr A8 ... yes my revive and refresh is ET will disassemble and reassemble w new components, parts, valve body, torque converter etc to make this a new trans. I have to ship my trans to GA. That’s why I was asking for a place to remove trans in SD. Any suggestions Dr A8?
KaMaKaZieP -ALUMIN8-
07-04-2004 10:50 AM
