1999 A8Q Fuel Filter
Re: 1999 A8Q Fuel Filter
It is located under the reare right side right before the rear tire.
It is hidden by a plastic cover. To change it you will need two ranches of identical size (don't remember what size)
It takes about 15 minutes to change.
WHen changing, make sure you eather replace compression washers, or do not lose old once.
Before closing the cover start the car up and verify that there are no leaks.
Before changing the filter, disconnect the battery just in case.
Be very carefull not to damage the tubes.
DM
DM
KYNZ
06-28-2007 06:39 AM
Biscuit141
Audi 100 / A6 (C4 Platform)
01-27-2007 09:49 PM
