Led conversion — warning light problem
Just installed led lamps in the rear running lights and brake lights. Unfortunately the dashboard warning light now comes on. Any idea how to remedy this?
thanks a ton! Steve
thanks a ton! Steve
I would first try (if you cannot return newly installed bulbs) load resistors...they will enable the computer to recognize the bulbs..though you will not retain the power savings, you will have functioning bulbs and "no codes." I would suggest the 50w versions available...
Blaster an
Q5/SQ5 MKI (8R) Discussion
11-08-2013 05:18 PM
Audis or VWs 4Life
10-13-2005 07:22 PM
