Engine type 4,2 petrol
The car as A8 d2, 4.2 liters petrol produced in 1997.01 under the passport power is 220 kW, 4 valves per cylinder. Engine code ABZ.
Valves needed to be changed according to the vin code, the diameter rod of both valves is 7 mm, and actually in the heads valves rod are 6 mm.
What the engine type I have?
If the valves got bent I'd recommend swapping in a decent used motor as they are generally pretty cheap and plentiful. Sorry I do not know the stem diameter. Otherwise maybe order a whole used head off Ebay ($200 USD) and make the best of all the resulting parts.
Thank you, but i have work on head, polish channels, so i want to complete the project.
elifaztemanita
30v V6 Discussion
12-11-2006 02:25 PM
